will this work?
Old Apr 27, 2006 | 09:46 PM
shortman1124's Avatar
will this work?
have a 2002 camaro its a ttop and im looking into getiing a set of c6 rims. the sizes are 19x10 and 18x8.5. will these rims fit? will i have to get any spacers or anything?
Old Apr 27, 2006 | 10:43 PM
ibanez6rg's Avatar
Re: will this work?
The fronts will fit fine and the backs might need a little work to get them to fit. Other than that you'll be OK. Stay away from spacers though.
Old Apr 28, 2006 | 10:06 AM
Re: will this work?
Factory wheels or aftermarket replicas? Do you know the offset or backspace of each wheel?
Old Apr 28, 2006 | 03:22 PM
Re: will this work?
they are oem rims. they were on a corvette though. what do you mean by a little work? will i have to modify anything?
Old Apr 29, 2006 | 10:34 AM
Re: will this work?
This is what Skulte Designs shows as the stock C6 wheel dimensions:
C6 Corvette 18x8.5 front (GM 9594351) 58mm offset; 6.53" backspace
C6 Corvette 19x10 rear (GM 9594353) 79mm offset; 8.11" backspace
You will need a spacer in the back.
Look at the Wheel and Tire FAQ, stickied at the top of the topics listing. Open the FAQ and go to the very bottom of the thread. There is a detailed explanation of what you need to do to put those wheels on your car.
Old Apr 29, 2006 | 08:21 PM
Re: will this work?
thanks
Red Hawk 94
Mar 18, 2019 04:03 PM
blac94Z
Feb 18, 2015 11:36 AM
squarehead
Jan 15, 2015 07:02 PM
phoenix95
Jan 8, 2015 02:44 PM
phoenix95
Jan 8, 2015 09:14 AM
