Cruise control not working
Old Apr 24, 2006 | 04:43 PM
LT1Formulation's Avatar
My cruise control is inoperable, where should I start looking after I verify that the fuse isn't blown?
Old Apr 24, 2006 | 05:11 PM
BitterOldMan's Avatar
Re: Cruise control not working
not sure on the f-body's, but I have seen a burned out CHMBL (center brake light) kill cruise in other GM cars.
Old Apr 24, 2006 | 07:27 PM
murphy54's Avatar
looks like all you need is lots ok luck...so good luck
Old Apr 24, 2006 | 08:07 PM
seawolf06's Avatar
This is a pretty widespread and common problem in these cars. Some have found that the 3rd brake light will go out and cause the cruise control to stop functioning. I replace my tail lights and it still doesn't work. I've heard of people replacing the entire cruise module and it still doesn't work, so basically, good luck, since there's no concrete solution.
Old Apr 24, 2006 | 08:45 PM
anaik's Avatar
On mine the brake pedal switch had moved. Easy fix.
Dec 1, 2016 05:37 PM
squarehead
Jan 15, 2015 07:02 PM
jayblev95
Jan 6, 2015 11:52 AM
Collector Car
Jan 5, 2015 10:58 AM
SLIMJIM
Jan 7, 2003 11:06 AM
