Re-fill?
Old Apr 18, 2006 | 02:25 PM
"White Knight"'s Avatar
Re-fill?
Okay this will be my first summer on the juice. One problem I don't have any juice to use. Where can I get it?
I am trying to find a place that I can get my bottle filled. Anyone in Michigan on here that knows a place, I am like 30 minutes north of Lansing and 40 minutes from Mid-Michigan Motorplex--There has to be one around here, but I just don't know where.
I will probably just have to go to the track and ask around.
Old Apr 18, 2006 | 02:27 PM
Re: Re-fill?
By the way how much a hit in the wallet to fill a ten pound bottle?
Old Apr 18, 2006 | 02:56 PM
snod83's Avatar
Re: Re-fill?
I am not sure of a place for you, but its somewhere in the 4 bucks per pound range. I have paid 3.50-4.50 a pound.
Old Apr 18, 2006 | 03:32 PM
Re: Re-fill?
http://www.holley.com/dealers/NOSDealerLocator.asp
Old Apr 19, 2006 | 01:06 AM
Re: Re-fill?
thanks
Old Apr 20, 2006 | 09:33 AM
trymy6's Avatar
Re: Re-fill?
I've been paying 4 bucks per pound at the local JEGS store for the past few years. I used to have the hookup at a welding shop for $2 per pound, but my firend no longer works there. Not sure if there is a JEGS around you...
Brandon
Old Apr 25, 2006 | 01:40 PM
WinSomeLoseNone's Avatar
Re: Re-fill?
WOW it is $6.00 a pound here is PA....i pay $60.00 to fill my 10lb tank... it tears your wallet up..
Edit*
WOW I went to that link on Holley and entered my info. Gave me a shop I didnt know existed, I called them and they said they fill for $4.00 a pound SWEET thats $40.00 a fill and $20.00 saved everytime !! THANKS
WOW ive wasted somewhere around $300.00 over the past few months!! YEA
Old Apr 25, 2006 | 02:31 PM
jsetzer's Avatar
Re: Re-fill?
Wow, I thought $2.75 was high...
Old Apr 25, 2006 | 04:27 PM
srsnow's Avatar
Re: Re-fill?
you can also call 1-800-99-refill which should be the same as the website version, not sure if they update them at the same time
Old Apr 25, 2006 | 08:24 PM
camaro81's Avatar
Re: Re-fill?
$2.50 a pound here in Raleigh, NC cost me $26 to get mine refilled yesterday
Old May 1, 2006 | 09:45 AM
93Phoenix's Avatar
Re: Re-fill?
How long does your N20 last on a 100 shot?
Old May 1, 2006 | 10:56 AM
trymy6's Avatar
Re: Re-fill?
Depends how much you spray it, and how much bottle pressure you have when you do spray it. If the bottle is room temperature and you're spraying at 600-700 PSI , the shot will be weak but you will probably get 15-20 good shots out of it. If you have a warmer ,and spray it with 1000-1200PSI the shot will be strong but will not last as long. Too many variables to be able to say for sure how long it will last. And remember, nitrous is not like Maxwell House Coffee, it's not good to the last drop I usually refill my bottle when it gets down to about 4lbs left.
Sunset_Z
Jan 6, 2009 02:25 AM
3whiterag
Sep 1, 2008 06:47 PM
LJM97Z
Apr 28, 2008 08:19 PM
z28rider78
N2O Tech
Feb 24, 2008 07:16 PM
