Anybody do an F1R on an lt1 yet?
Old Apr 17, 2006 | 07:56 AM
Jeff 96 SS's Avatar
I have an anoying seal leak on my D1 that is oiling my belt up. I will fix it but I was planning to go bigger next year anyway and I may do it now. What do you all think about an F1R on a well built 396 LT1?
Jeff
96 SS BLOWN
96 TA 396 D1
Old Apr 17, 2006 | 09:27 PM
drivefast4fun's Avatar
Re: Anybody do an F1R on an lt1 yet?
Never seen it, and the guy on the phone at ATI had told me that the D series was the biggest that would fit without fabrication. Of course that was about a year and a half ago.....so I say do it. Then call out an 8 second import and take them out as well!
Old Apr 17, 2006 | 09:32 PM
Jeff 96 SS's Avatar
I figure their will be a little Fab work but it is only a little bigger I think I can make it fit. the piping will be the creative part. I'm about ready for an 8 second import now Pretty damn close with the current setup. Jeff
Old Apr 18, 2006 | 07:20 AM
Sean94Z's Avatar
I haven't seen anyone with one, but from what I heard, you just have to make those aluminum stand-offs a bit bigger so the blower clears the block, and move your fans forward about 1/2"..
Old Apr 20, 2006 | 05:25 PM
Jeff 96 SS's Avatar
Nothing? Am I the only one crazy enough to try this ? Jeff
Old Apr 21, 2006 | 12:04 AM
BADST95's Avatar
Smile Re: Anybody do an F1R on an lt1 yet?
I have an F1 on my LT1 using the D1-SC brackets. I had to grind off a little bit of the block to make the F1 fit. The F1R is a decent amount bigger than the F1 and I highly doubt that the F1R will work without having some custom brackets fabricated.
Old Apr 21, 2006 | 08:01 AM
Jeff 96 SS's Avatar
Did you use the D1SC brackets or the D1 brackets? I have never heard of having to grind the block for an F1.
Old Apr 21, 2006 | 09:08 AM
markinkc69z's Avatar
The F1 is approz .400 thicker so it moves the volute rearward causing it to hit the block until you grind clearance. The volute itself is identical externally to a P1SC or D1SC. The F1R will not fit between the block and bracket with the standard bracket orientation. Parts would need to be fabricated.
Old Apr 22, 2006 | 10:19 PM
tubby's Avatar
ditto all that. the f1 fits with a little grinding good luck on the f1r.
Old Apr 25, 2006 | 02:22 PM
96 WS6's Avatar
Keith from Force Fed Performance in Roseville has an Lt1 with an F1... among other things.
Old Apr 25, 2006 | 04:02 PM
BADST95's Avatar
Thumbs up Re: Anybody do an F1R on an lt1 yet?
That's fantastic.
Old Apr 25, 2006 | 06:59 PM
96 WS6's Avatar
Originally Posted by BADST95
That's fantastic.
I know that's why I wrote it.
oldschool
Feb 9, 2016 09:21 PM
Mar 15, 2015 07:01 PM
Noer
Feb 28, 2015 11:29 AM
InfernalVortex
Jan 17, 2015 09:35 AM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
