Momentary switch wiring
Old Apr 7, 2006 | 09:24 PM
Red97LT1's Avatar
Anyone know how I could wire a momentary switch in the console to allow lock/unlock from inside the car besides the remote? I put an alarm/keyless entry system in a friends car and the previous installer had it wired that way.Thanks
Old Apr 7, 2006 | 11:13 PM
stroked383z28's Avatar
Re: Momentary switch wiring
Assuming this is for your car all you would have to do is wire up whatever switch you buy to ground the red/black wire in the car to lock the doors. To unlock you will need two relays (should already be installed if you have an aftermarket keyless) and wire each as a 5-wire setup with the two unlock wires in the car. Then just use the same switch to send terminal 85 on both the relays to ground to unlock the doors. Each relay would be wired like so:
85 -- momentary switch (goes to ground when pressed)
86 -- +12 volts constant
30 -- motor side of cut unlock wire
87a -- car side of cut unlock wire
87 -- +12 volts constant
EDIT: The unlock wire colors are tan for driver's door and gray/black for the passenger door.
Heathen1
Jan 2, 2016 04:27 PM
Lt1son
N2O Tech
Nov 25, 2014 01:52 PM
Ryabut98
Sep 3, 2002 11:45 PM
Matt-01-SS
Aug 2, 2002 04:05 PM
