Loose door skin
Old Apr 6, 2006 | 09:56 AM
95GRNZ's Avatar
Question Loose door skin
The door skin on the passenger side has come apart for about 10 inches from the top of the door down. I happened to notice it when I closed the door and saw the sking flapping a couple of times after the door closed.
What kind of adhesive should I use to glue it back on? Any and all help, info, tricks etc. are greatly appreciated.
TS
Old Apr 6, 2006 | 12:14 PM
Z28SORR's Avatar
Re: Loose door skin
Go to your local dealer or any body shop (or body shop supplier) they will have the glue you need. Remember when you glue things the mating surfaces have to be clean, clean, clean.
Old Apr 6, 2006 | 12:50 PM
95GRNZ's Avatar
Re: Loose door skin
Yeah, cleanliness is definetely a must. It is, however, quite diffcult to scrape any of the extra stuff off the door frame and sking since there is not much room to stick anything in between there...
I guess I'll check with the local dealer first to see what they suggest. Might be the type of task which is better left for professionals, though...
Old Apr 7, 2006 | 07:44 PM
Rogue Leader's Avatar
Re: Loose door skin
Hey man, I'm sorry this issue has popped up. I have had this problem before on my sisters 94 and on that car on the drivers door. I used professional all weather silicone on both and never had a problem. My sisters car lasted like that for 4 years till we sold it, the TA I did the same on the front of the drivers door. Its really no big deal to fix. I'm surprised i never even saw it on the car. Sorry!!
Aaront810
Aug 29, 2020 09:34 PM
2QUIK6
Sep 17, 2016 02:31 PM
IndyZman
Oct 22, 2015 02:17 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
z28cam1993
Sep 9, 2015 04:08 AM
