Where to put fogger nozzle w/ Vortec intake elbow?
Old Apr 5, 2006 | 06:54 PM
camaro81's Avatar
I was about to drill and tap a hole in my intake elbow for my fogger nozzle when I remembered that this thing has a divider all the way through the elbow. No matter where I put the nozzle, it'll be directed into only 1 of the 2 blades in the throttle body.
Will this create nitrous distribution problems inside the intake?
It may sound like a dumb question to some, but I'm new to nitrous and dont wanna tear my stuff up :P
Thanks
Old Apr 5, 2006 | 11:28 PM
LT-7's Avatar
Re: Where to put fogger nozzle w/ Vortec intake elbow?
I think a plate setup would be best with the vortec elbow. I have the same one and plan to use the NX plate.
Old Apr 6, 2006 | 02:26 AM
Ok4thGen's Avatar
I dont think a plate would work with the vortec elbow,
i ran a plate tnt kit and had ALOT of trouble getting the stock rubber elbow on the car.
Old Apr 6, 2006 | 06:41 AM
camaro81's Avatar
I have a compucar plate that I'm replacing with a fogger nozzle because of various problems. The plate is pretty dang thick and barely fits, I had to grind a lot off my thermostat housing and I still have a vacuum leak past the plate and it just doesnt seem to run right when I spray it.
I was told a fogger nozzle is a little better since it gives the mixture more time to atomize and is a bit better at distributing it.
I have to give it a shot though. I'm gonna try putting it on the passenger side of the elbow right in the inside of the curve so it sprays diagonally towards the passenger side. If I have any problems with one side running leaner than the other, I'll just have to buy a new intake elbow.
Old Apr 6, 2006 | 08:33 AM
OffspringZ28's Avatar
nx has an LT1 plate? damn ive been out of the game for a while
Old Apr 6, 2006 | 11:12 PM
LT-7's Avatar
O! I mean nitrous works.
Old Apr 10, 2006 | 08:46 PM
nosfed's Avatar
I just ordered a Trick Flow elbow for mine and it seems to fit. Haven't had the blower hooked up so I can't tell you whether there are any other problems.
formula218
Dec 2, 2014 04:27 PM
RedLineRev
Jan 23, 2003 03:51 PM
slothgrant
Aug 22, 2002 03:01 PM
turbo_Z
Aug 19, 2002 10:50 PM
30thZ286speed
Aug 3, 2002 04:54 AM
