ls1 true duals
Old Apr 4, 2006 | 11:46 PM
Welds's Avatar
ls1 true duals
are any of these duals good? im looking for a set. my car came with shorty headers, can i still use these duals or do i need longtubes?
http://search.ebay.com/search/search...als&category0=
Old Apr 5, 2006 | 06:36 AM
teke184's Avatar
Re: ls1 true duals
"no, you cant use shorties with those, you absoltely have to have lnog tubes unless you wanna start fabbing up a custom Y pipe,"
whoa...easy killer
you CAN use shorties with those setups, although it won't be a direct bolt up. you'll have to have a shop make the connection pipe from the header collector to the collector on the exhaust. it probably wouldn't even be too difficult, you could probably use the front part of the current Ypipe (from the shorties) to make the transition.
not a major setback...but some custom fabbing to consider.
"unless you wanna start fabbing up a custom Y pipe"
why would he need a ypipe fabbed up to run duals????
Old Apr 5, 2006 | 08:31 AM
2000slp2768's Avatar
Re: ls1 true duals
since you are already looking at exhaust fab work, you should check with your local exhaust shop to see what they would charge you for making one.
Old Apr 5, 2006 | 12:57 PM
GhostZ28's Avatar
Re: ls1 true duals
i'd do it for only 1 arm and 2 teeth. Its not that hard to do, if you have a freind that knows how to weld, make some measurements and have them do it. you might have to drive areound for a day with open headers... =) but who wants to do that.. =)
Old Apr 5, 2006 | 01:45 PM
RussStang's Avatar
Re: ls1 true duals
Originally Posted by Taintedz28
I said fabbing up a new Y pipe because that kit that he pointed out WILL NOT work with shorties as it is now. Yes it will work if you CREATE/MODIFY a Y pipe for it. and I doubt most people want to start making stuff like that or have a shop charge an arm a leg and 4 teeth to make one
No, I am pretty sure what Teke meant is why would you need a y-pipe for a true dual exhaust setup???
Old Apr 5, 2006 | 04:30 PM
Welds's Avatar
Re: ls1 true duals
thanks guys, looks like il get a set of pacesetters before i buy some duals
Old Apr 5, 2006 | 10:15 PM
GhostZ28's Avatar
Re: ls1 true duals
OH, my bad I read that part wrong gah sorry about that im home sick with the flu still and not really all the way there
JEEZ me too. everyones sick lately!
Old Apr 11, 2006 | 10:44 AM
02ramair's Avatar
Re: ls1 true duals
id definately go with the lt's. good luck man.
Slayer
Aug 17, 2015 03:55 PM
meissen
Aug 11, 2015 06:05 AM
Jocofire1
Aug 7, 2015 03:16 PM
Catmaigne
Jul 14, 2015 05:17 PM
mrwz28
Jul 8, 2015 09:11 PM
