Ignition Switch Question.???
Old Apr 4, 2006 | 02:26 PM
95_z28_4_Ivan's Avatar
Sometimes When I Turn Off The Engine And Step Out Of The Car, The Radio Remains On, So I Have To Go Back And Play With The Key Til It Turns Off The Radio.
Any Suggestion On How To Fix The Problem?
Thanks
Ivan.
Old Apr 4, 2006 | 03:49 PM
Re: Ignition Switch Question.???
anybody???
Old Apr 4, 2006 | 04:34 PM
Could be your key switch is worn and its stopping somewhere between the "accessory" and "off" positions, and letting you remove the key - leaving the switch in the "accessory" position. Or there might be a problem with the retained accessory power (RAP) module that provides power to the radio and windows for 10 minutes or until you open a door.
Old Apr 5, 2006 | 03:44 PM
fi the switch is worn out, what can I do to fix it??? just replace it ?? or is there more toit ? how do I remove it?
thanks 4 the help!
Latronaxe
Jul 20, 2015 12:00 PM
RUNMYTA
Jul 15, 2015 07:50 PM
robyyzpapa
Jul 7, 2015 10:05 AM
chevyalltheway
May 24, 2015 04:26 PM
