12 Bolt and Rattles
Old Apr 1, 2006 | 02:43 PM
GMCAMARO's Avatar
12 Bolt and Rattles
I replaced the 10 Bolt over the winter with Moser 12 Bolt. I took the car out for the first time on Thursday and again on Friday. I was surprised by how many rattles there where. Especially over bumps, they appeared to be coming from the rear end. I ensured everything was tight. Any suggestions?
Old Apr 1, 2006 | 10:18 PM
96speed's Avatar
Re: 12 Bolt and Rattles
Check, recheck, and check the torque arm bolts again. They are prone to loosening!!!
I should have gone with a strange OR 9" .
Ryan
Old Apr 2, 2006 | 11:44 AM
xxsaint69x's Avatar
Ryan
you guys need to learn to how to tighten stuff propertly, i never have any problems with mine coming loose on my Moser. But then i use a big pipe on the end of the rachet and planty of red loctite.
Old Apr 2, 2006 | 02:33 PM
Also need to post in the correct forum . This doesn't belong in Advanced Tech...... moving to Drivetrain.
Old Apr 2, 2006 | 04:21 PM
StudyTime's Avatar
Oh, the irony. We need to learn to tighten properly?
If you're rattling when you go over bumps make sure your rear anti-sway bar is not interfering with the cover on your 12-bolt. Look for shiny spots on the cover or the bar.
Ben T.
Old Apr 3, 2006 | 05:31 PM
96speed's Avatar
Funny, I thought lock washers, loctite, and about 90 Ft-lbs would help me beat the documented problem by multiple other Moser owners. I must be using the wrong end of the wrench!
Ryan
Richardan15
May 30, 2015 08:36 AM
BigWil
Mar 29, 2015 12:24 PM
maybe2fast
Mar 16, 2015 09:45 AM
jayblev95
Dec 1, 2014 06:55 AM
squarehead
Nov 21, 2014 08:02 PM
