View Poll Results: Which Option?
Keep L98, Heads, Cam, Intake in some form
9
75.00%
Cheap Crate, use existing TPI intake
16.67%
Rebuild LT1 with a Rod Knock, cam.
8.33%
Voters: 12. You may not vote on this poll
Decisions, Decisions...
Old Mar 22, 2006 | 07:51 PM
LesPaulGoth's Avatar
Well guys, summer is coming up soon for me. I get out of college early May and start working, and plan on making 5000$ after taxes this summer. Half of that, I want to devote to my car which is an IROC 350 TPI, pretty much stock other than headerback exhaust, and a shift kit which I will be installing this weekend hopefully.
Right now I have three options:
Option 1) Heads and Cam, port the hell out of the intake, and maybe pick up a set of SLP runners and siamese the hell out of those as well. Dutweiler Trick Flow heads, and a cam with close to .500 lift.
Option 2) Get a cheap crate motor with no intake, such as the one here http://goautocenter.com/320hp_alum__head.htm (also, scroll down, there is a 400hp engine for 2500$) and put my existing intake on it. I know that the HP numbers would be off thanks to the intake, but it would be relatively in the ballpark I think.
Option 3)
(I just learned this today) Pick up an LT1 out of a 93 Trans Am and drop it into my IROC for next to nothing. The motor I can most likely get for less than 500$. The issue with this is that the motor has a rod knock, so I would end up rebuilding the entire bottom end, and doing piston rings while I was at it. That, I believe would wake the motor up a bit and have her running well. This idea is actually my favorite, since I will essentially be getting the motor and rebuilding it for under 1000$ (minus the can-o-worms fund).
Which option do you think will be the smartest out there to do? What kind of numbers can I expect from an LT1 (maybe get headwork done and a new cam =) ) after a rebuild? Any other opinions?
_Clark
Old Mar 22, 2006 | 08:00 PM
2000GTP's Avatar
Re: Decisions, Decisions...
I'm leaning towards option 1.
Old Mar 22, 2006 | 08:56 PM
What HP #s do you think I could get from options 1 and 3? Forgot to throw that in there.
Old Mar 22, 2006 | 09:28 PM
89Vert's Avatar
option 1 and get chip burner/emulator and learn how to use, pulleys give good power
I have alot of experience with LT1's and I hate them,
L98 with a mini ram or converted LT1 intake would be the road I would chose over an LT1
I run 350's with my exhaust only 305 cause of my chip burner/emulator
www.moates.net
Old Mar 23, 2006 | 02:38 AM
thirdgenrallysport's Avatar
option 1 with a Holley Stealth Ram
Old Mar 23, 2006 | 10:53 AM
85_305's Avatar
If you can afford it, go with option #2. Otherwise, do #1. Nothing wrong with building up an L98 and showing the lt1/ls1 crowd up
Old Mar 23, 2006 | 02:38 PM
1987IROC350's Avatar
Hmmmm. I would go with option 2. You should add a poll to your thread.
Old Mar 23, 2006 | 04:46 PM
Will do, thanks so far guys
Old Mar 23, 2006 | 11:50 PM
85_305's Avatar
I voted Keep L98. You can make just as much power on an L98 as you can an LT1. HSR, beefy cam, a good pair of heads, full exhaust and you are damn near 400hp give or take (depending on setup..)
Old Mar 24, 2006 | 12:43 AM
91Z-28's Avatar
I agree.
Old Mar 24, 2006 | 08:08 AM
V8Rumble's Avatar
I chose option #1 as well - and the setup described above is pretty much exactly how I'm building mine (a StealthRam intake, AFR 195 heads, SLP headers, etc.). I'm expecting/hoping for a conservative 325 - 340 HP when it's done - but now I'm wondering if I shouldn't just build the short-block as well, & if I do THAT, I'm just gonna go "*****-out" & make it a forged 383.
If I get done before you (or if I ever get done at all ), I'll let you know how it works out!
Old Mar 24, 2006 | 08:19 PM
91Z-28's Avatar
That is a very conservative estimate for your AFR 195 combo. A stock ZZ4 crate with HSR makes 295-310rwhp and 365-370rwtq. And that is with 196cfm@ .500 heads.
Old Mar 25, 2006 | 08:10 AM
V8Rumble's Avatar
Yeah, but I'm used to people who go overboard with their estimates - and I still have to deal w/ emissions here, so that's going to somewhat limit my cam choices also. (Going to try to make up some of that lost power by using little tricks like coatings, etc.)
However much power it makes, it's bound to be a lot more fun than it is now!
Old Mar 25, 2006 | 07:06 PM
Awesome guys, thanks for your input. After talking to a few others as well, I've decided that Option 1 it is! Now, I know that it seems kind of ballpark, but what gains MIGHT I expect from Trick Flow 23* Kenny Dutweiler Series Heads, a cam in the 490-500 lift area, custom Prom, and MAYBE HSR? After looking around at other setups, I estimate around 375 crank. What do you think? Oh and is it bad that this is my daily driver? Ha, oh well, too late =)
97SSdude
Aug 21, 2015 09:36 AM
89 Iroc-z28
Jun 30, 2015 11:19 AM
cmsmith
Jun 4, 2015 07:35 PM
SmoknZ28
Jan 28, 2003 09:39 AM
99huggerorangeZ
Nov 21, 2002 08:46 PM
