South Atlantic Delaware, Florida, Georgia, Maryland, North Carolina, South Carolina, Virginia, and West Virginia
Need Gears & Stuff
Old Nov 3, 2002 | 05:17 PM
Manaz101's Avatar
Angry Need Gears & Stuff
Well i've gotten different unbias opinions and they tell me the same, that my gears are very loud and sooner or later they're going to go out on me, so i better see to getting new ones. I suspected it all along, they have been sounding more and more over the months, but i choose to ignore it. So i guess now i have to look to replacing them. Well i've got several questions:
I have 2.73", should i keep them or go up? 3.42's or higher?
What exactly do i need to buy and do when i go up in gears?
What besides the gears are in that girdle that i would need to replace?
Can i pick up what i need at the junkyard?
I don't know i need help!
Old Nov 3, 2002 | 08:26 PM
94REDSTALLIONZ's Avatar
hey bro,
i will sell you my gears out of my 2000' z28..my stock ones that is they only have like 5,000 miles or so on them..they are in absolute FLAWLESS condition...i will let them go WITH the slp carrier for $75.00 if thats cool..they are 2.73's with the thorsen carrier.later!
carter
Old Nov 4, 2002 | 02:02 AM
MustangEater82's Avatar
If you check *shudder8 www.slponline.com * shudder8 I know they seel takeoff gears that were barelyt used like 10 miles on them for pretty cheap. just SLP sometimes likes to take their time shipping stuff. I would trust those mroe then used gears, well the guy posted above looks like he has a nice set of gear for sale too.
Old Nov 4, 2002 | 01:52 PM
Manaz101's Avatar
Man.......i just got off the phone with SLP and looks like they'll charge me around $400 to go down in gears on my car! That's alot of money......i think i might have to stay with my gear ratio as it is now. I'd still have to reprogram my PCM, and 93's i have to get a whole new chip! Why do our cars have to be so expensive!
94REDSTALLIONZ ~ i might have to hook up with you for those gears........even though i wanted different ones......i can't afford them. I'll let you know, thanks!
Does anyone else have any ideas??
Old Nov 5, 2002 | 08:31 AM
Manaz101's Avatar
Question
GU5 - is 3.23 gears right??
If so, those are the ones i have. Would i still need a 3 series carrier, no right because i already have one. So i could just dump some 3.42 or 3.73 right?
Also, my mechanic suggested i just buy a new "pumpkin" with all the bearings and bolts in them already calibrated. Do you guys know how much that'll be???
Old Nov 5, 2002 | 09:43 AM
correct bro,
3.23's is gu5...good news though.SLP sells a diff chunk for only $99.99 3 series carrier..very nice epice..thats what im running in my car right now with GM 3.42 gears..pretty strong..u might want to also pick up a stud girdle from TAperformance.com they have them for semi cheap..this set up holds consistant 1.4-1.5 sixty foot times in my car...very nice 4 the price later,
carter
Old Nov 5, 2002 | 10:10 AM
Manaz101's Avatar
So i would i just be looking at the diff chunk, gears and maybe the girdle?
Old Nov 5, 2002 | 10:26 AM
yep thats it go to www.slponline.com and look under part # 64501T that is the differential...then www.ls1motorsports.com under lt1 section..they have motive gears for $175.00 and the same place for the stud girdle (optional) $165.00 with stud kit..(make sure you get the stud kit!!)not too shabby...damn good set-up 4 the price again later,
carter
Old Nov 5, 2002 | 01:24 PM
Manaz101's Avatar
Thumbs up
Thanks!
Old Nov 5, 2002 | 03:44 PM
Anytime bro..goodluck..later!
carter
Old Nov 5, 2002 | 06:44 PM
Soma07's Avatar
If you keep an eye out in the forsale section used 3.23/3.42 gears usually go for ~$50.
Add the SLP posi and installation and the rearend should be like new for less than $400 (including labor).
Old Nov 5, 2002 | 07:30 PM
Manaz101's Avatar
Yeah, I've been checking the for sale section and on ebay. Hopefully i can get some cheap. What's going to kill me is the diff and the installation kit!
Old Nov 5, 2002 | 10:17 PM
Soma07's Avatar
Also keep your eye out for an entire rear end. That would save you the cost of the install kit since everything would be setup.
My rear was dying so thats what I did. After a few weeks of looking I found one in Ft Myers for $200.
Plus IMO its easier to swap the entire rear than to setup the diff and gears so you might be able to do the work yourself.
Just something to think about...
BPS
9
Mar 5, 2015 10:51 PM
Hotrods&Muscle
Jan 28, 2015 09:35 PM
Hotrods&Muscle
Jan 24, 2015 09:57 PM
Hotrods&Muscle
Jan 18, 2015 08:08 PM
Hotrods&Muscle
Dec 21, 2014 03:57 PM
