ya or nay on sts turbo
Old Feb 10, 2006 | 11:25 AM
jmh96z28's Avatar
in thinking og gets a sts turbo system with my 383 stroker set up.let me here all your thoughts on the sts set up and why its good or bad.
Old Feb 10, 2006 | 11:33 AM
Roadie's Avatar
Re: ya or nay on sts turbo
try the search feature... there's plenty of threads on this subject.
Old Feb 10, 2006 | 04:49 PM
cbrakllr88's Avatar
the sts system is good but I would go with a front mounted turbo. Try GMRspeed.com or hi -flo turbo kits but there pretty backed up from what I hear. Good luck on your F.I. purchase.
Old Feb 10, 2006 | 04:54 PM
snorkelface's Avatar
Is the GMR ready for the LT1 yet? I kept posting asking for updates on it, but they never responded. I ended up going with a PTK kit.
I would have gone STS, but I am lowered, and plan on going down to approx 2" lowered total, and would have ground-clearance issues.
Old Feb 18, 2006 | 11:52 PM
fabgmc4me's Avatar
GMR Speed is in the process of mocking up the LT1 Front mount kit currently on my car. The kit will be similar to their LS1 kit from what they told me. They should have them ready for purchase in the next few months. My car will be a completely built 383, and most likley a T76. I'll post updates on my car as it progresses.
Old Feb 19, 2006 | 12:26 AM
MMC Racing's Avatar
I am in favor of the STS kit..
They are making some serious power with their kits..
We are Authorized Dealers of STS kits.... So when your ready call us or PM me and I will get you a Kick *** Deal!!
Thanks..
Old Feb 19, 2006 | 03:47 AM
Honda Hunter's Avatar
Thanks..
Like what on LT1's?
Old Feb 20, 2006 | 09:20 PM
LukeZ28's Avatar
An option I haven't seen many go with (if you already dont have longtubes) is to go with the LT1 kit which runs the intake pipe up the center over the Kmember and run shorty headers. I don't see longtubes making much of a difference and there is no ground clearance problem with the LT1 STS kit even on lowered cars like mine. I have been running the base kit for about 3 years strong.
Old Feb 20, 2006 | 09:32 PM
That's weird. When I looked at the kit online, it looked like the piping drooped down pretty far under that axle, and was exposed running under the car.
Old Feb 20, 2006 | 10:00 PM
NJLT1SS's Avatar
I saw an STS system being installed on a car at a local shop. It seems like with this kit that you loose the drivers side subframe connector to install the intake pipe that runs from the turbo to the throttle body. And yes, the pipes do hang down low, and looks kinda rediculous when you see it on the road. Hey, how come you have one subframe connector sitting in your closet.......
Nick
Old Feb 20, 2006 | 10:02 PM
LukeZ28's Avatar
Here is an under side pic of an LT1 kit, and some others on the page where you can see the difference from the LS1 kit.
http://www.jlturbo.com/imgs/LT1_bot.jpg
http://www.jlturbo.com/eyecandy.htm
Added:
Installation fitment with the rear LS1 pipe can be tweeked to fit better, sorta learn little tricks after working with them a while. Yes, with the LS1 kit you would loose the SFC on the drivers side unless you did some additional fabricating.
Old Feb 21, 2006 | 04:37 AM
5.0THIS's Avatar
I saw the kit on an LS1 Formula (Might have been a TA, I dont recall) that was stock height. The rear pipe going under the rear axle was about 3 inches off the ground at one point.
Old Feb 21, 2006 | 06:42 AM
RealQuick's Avatar
I thought both pipes went over the rear axles (intake and xhaust pipes)?
Old Feb 21, 2006 | 07:45 PM
NYSS Guy's Avatar
Both pipes do go over the rear end. The charge pipe just before the rear tire, is usually the lowest point on the kit. But, I'm stock height, and never hit that pipe on anything. It could also be modified to alleviate some of that...if it's that big of a concern.
Old Feb 22, 2006 | 04:16 AM
5.0THIS's Avatar
I'm talking about where NYSS guy is saying. I think it's dangerously low there, not to mention the pipe that "replaces" the subframe connector. To me that is probably even more vulnerable.
