Really need help on which rear to use for my future hp and torque goals.
Old Feb 6, 2006 | 09:55 PM
RedBanditz28's Avatar
I am planning on having a new forged engine installed and using a turbo system. In genreal, i mostly plan on running at a low boost. Maybe something along the lines of 500 Rwhp around town. I would only go to the track maybe once or twice a year to turn up the boost to make it reach 750-800 Rwhp. I mostly keep the car garaged and don't even use it as a daily driver. I'll take it out once or twice a week in summer if i have time.
So having told you the way i use my car and what my goals are, can you recommend which rear to use? I have emailed people who build rears, and some have told me thats right in between the use of a 12 bolt vs. 9 inch.
I am mostly looking for reliability.
Also, if you can recommend which gears for the rear. Maybe even give some pros and cons of both rears. Things like the difference between a posi and spool amongst other things. I am new to discussions of Rear ends on cars. I greatly appreciate the help.
Old Feb 6, 2006 | 10:31 PM
blackztpi's Avatar
Re: Really need help on which rear to use for my future hp and torque goals.
as much as i hate ford, i'd have to choose the 9". it's easier to setup and workv on and it's a better design really.
Old Feb 9, 2006 | 07:31 PM
lethal93ta's Avatar
yep. the ford 9 hands down is better, Im not a ford fan eather but I got a moser 9 for my car and love it
Old Feb 9, 2006 | 08:57 PM
rskrause's Avatar
What tranny are you planning to run? What use do you to optimize the setup for? What tire will you be using?
Rich
Old Feb 11, 2006 | 11:54 AM
I haven't even decided on a tranny yet. Open to some options from you guys about that. Although i assume the shop that is building me the negine and turbo setup are prob going to end up building the tranny accordingly. The setup is going to mostly be for a street setup. May see the track in a distant future, but i plan on showing the car off before i start ruining things on it by drag racing it at the track. I am going to stick with the tires i already have on my car. I have 18 in rims and have 245/40's in the front and 275/35's in the rear. The fronts are BF G Force KDWs and the rears are BG Goodrich G force DOT Drag Radials.
Old Feb 11, 2006 | 09:53 PM
RicocheT's Avatar
Do you mind if I ask how much that setup ran you from moser? complete? I've played with the idea of getting a 9" for my car, I hate to for a mostly street setup but I'd like to play with it on the track some too.
Old Feb 11, 2006 | 10:02 PM
lethal93ta's Avatar
I get cost on everything I got sence I work at a place thats a dealer for them, over all I think I spent around 2400 to build it myself me doing all the work, I just ordered the rear housing/axles, third member, pinion support and the spool from them, everything else I got from our local supplyer the gears and bearings ring gear bolts, you can add probably about 20% on top of that if you would order it direct from them, they charged me like an extra 100 to put the rear support on there to.
Old Feb 11, 2006 | 10:44 PM
rskrause's Avatar
With those tires you won't have to worry about breaking the rear end. It's going to be spin city when the turbo spools up. So, I would say it really doesn't matter.
Rich
F'n1996Z28SS
Aug 23, 2023 11:19 PM
owen66
Nov 30, 2014 04:21 PM
