Can I make a Man.Fan. Switch with this switch?
Old Jan 27, 2006 | 10:20 AM
Need4Camaro's Avatar
Its an ON - OFF - ON switch...
The back on it looks like this...
- Accessory (Top)
- Supply Volts (Middle)
- Accessory (Bottom)
Is there any way possible I can make a Man.Fan. switch with just that switch as it's just the right size and I can't fit anything larger on the panel... I am willing to use Relay's if need be but I need information on where to route all the wiring.
Old Jan 27, 2006 | 04:12 PM
shoebox's Avatar
Re: Can I make a Man.Fan. Switch with this switch?
If the fan wiring is the same as LT1 years, you can use wiring diagrams on my Tech Page. You need a DPDT switch. The switch you describe could be a DPDT or SPDT (dual pole or single pole, double throw).
meissen
Jun 1, 2015 07:59 AM
Jan 23, 2015 01:13 PM
siguy
Nov 27, 2014 10:07 AM
Rich_z28
Aug 29, 2002 10:44 PM
