Coolant level low??
Old Jan 25, 2006 | 06:47 PM
jamieSS's Avatar
Arrow Coolant level low??
My coolant level low light is on but my coolant is full. The light comes on about 5 minutes after i start driving but is off when i just start it up. Some one told me it may the sensor but... how do i check it?
Old Jan 25, 2006 | 09:12 PM
moparman's Avatar
Re: Coolant level low??
That's a common problem. The sensor mounts on the radiator by the battery. You can take it out and clean it and see if that works, or do what a lot of people have done: disconnect it.
Old Jan 26, 2006 | 08:32 PM
wunfunLT1's Avatar
My '93 Formula low coolant light has flickered now and then since I got it (40kmi ago). I changed the sensor ($34) and it does exactly the same thing.
I think that air bubbles going past the sensor makes it act that way. Ignore (best solution) or disconnect. Good luck.
Old Jan 29, 2006 | 05:50 PM
buzz12586's Avatar
How hard is it to disconnect and where exactly is it located??
Old Jan 29, 2006 | 06:39 PM
moparman's Avatar
Take the battery out, and you'll see it sticking out of the radiator.
Old Jan 29, 2006 | 08:11 PM
buzz12586's Avatar
Sweet thanks. I'll have to give that a try next time I am under there.
calaban
May 18, 2020 06:43 PM
BMX Dad
Jan 23, 2015 07:00 PM
AlaskaZ28
Dec 16, 2014 07:24 PM
AlaskaZ28
Dec 10, 2014 02:39 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
