Dyno Q:
Re: Dyno Q:
I don't know if they actually put stuff in the computer or not. They didn't ask me what I had when I got dynoed. My numbers didn't match up either, about 30 HP less than I thought (I should be 130RWHP stock, but I got 122RWHP...way off). I'm pretty sure it's from my bad torque converter which is being worked on as we speak.
But when I got my printout at the front desk, he was asking the guy that was going up next what mods he has, so I'm confused. Maybe they didn't care about me because it was a mustang place.
Re: Dyno Q:
Originally Posted by spinish
When you get your car dynoed what do they put in the computer? Like gears, tire size, stuff like that. cuz i got some numbers that just don't match up.
Re: Dyno Q:
I had it dynoed. and on the dyno they had a drag strip simulator on it.It said I crossed that line at 5900 rpm at 99 mph. But with my gears and tires and that rpm my mph is 107.07. It ran 13.2 with 1.7 60' but only 99 mph at the top end.But the math said other wise on the mph.
Re: Dyno Q:
That will make a big difference.
Was it tied down tight?
Were the tires spinning on the rollers?
Re: Dyno Q:
the tire pressure is 25 psi. (street tire) I don't know if it was tied tight. And it smoked the tires on the rollers through first gear.
Re: Dyno Q:
tdigger9899
Sep 7, 2015 10:56 AM
