how to disable vats and egr using cats tuner
Old Jan 18, 2006 | 03:21 PM
oneslowz28's Avatar
how do i dissable the vats system and the egr system using cats tuner? aslo does anyone have a good tune for a stock 94 z28? i boutght a stock 94 today at auction and im thinking of using it as a daily driver and would like a good tune for it. the 95 is fixing to be built and the 94 in my sig is now a strip only car.
Old Jan 20, 2006 | 03:32 PM
LT-7's Avatar
Re: how to disable vats and egr using cats tuner
You would first load up the tune from your stock ecu, then in the tables menu go to the switch table. I think its the first one. You will have a list of "switchable" systems. There will be VATS and lower on the list there will be a EGR test that you can turn off.
Old Jan 20, 2006 | 08:32 PM
oneslowz28's Avatar
done and done. thanks.
Old Jan 20, 2006 | 10:09 PM
LT-7's Avatar
No problem, it just gets harder from there.
Aug 24, 2015 06:41 AM
Aug 7, 2015 08:52 AM
MichiganSkip
Aug 6, 2015 09:38 AM
CARiD
Exhaust System
Aug 3, 2015 05:10 AM
