biggest tire
Old Dec 27, 2005 | 06:11 PM
SAINTSFAN's Avatar
Smile biggest tire
hey guys/gals what is the biggest tire you can fit on a 95ta stock rim with or with out spacers...thanks
Old Dec 27, 2005 | 10:52 PM
Re: biggest tire
The biggest "high performance" tire you will find for a 16" wheel will be a 255/50-16, and that fits with no modifications. BFG has some hard to find Radial T/A tires in wider widths for 16" wheels, up to 275's, but they tend to be very large diameter tires, which either will not fit in the wheel wells (28" is pretty much the limit), or if they do, they will be so big in diameter that they will slow you way down, like swapping in a lower numerical rear axle ratio. You don't want to go over 26" diameter, unless you're running 4.10's or higher.
Novo
Wheels and Tires
14
Oct 12, 2015 11:20 AM
WPHIG2
Aug 27, 2015 06:37 AM
Latronaxe
Jul 20, 2015 12:00 PM
whitehooptie
Jul 12, 2015 06:10 PM
Slayer
Jul 4, 2015 03:06 PM
