Weld Prostars. Tubes or no tubes? Confused...
Old Dec 27, 2005 | 03:11 PM
RamAir95TA's Avatar
Hey guys. Just picked up a set of Weld Prostars from Summit. I'm planning on using 26x10.5x15 ET streets with them, and I have a set of tubes. Here's my question/problem/dilemma. Reading the literature that came with the wheels say that they are designed for TUBELESS ONLY tires. Why is this?
Do I need to buy another set of tires? Or can I go ahead and use my tubes with the ET Streets and Welds without a problem?
Really need some information. Thanks.
Old Dec 27, 2005 | 04:53 PM
Lonnie Pavtis's Avatar
Re: Weld Prostars. Tubes or no tubes? Confused...
The wheels will work with either tube type or tubeless tires. You may have to drill the stem holes larger for a drag slick type tube.
Your ET streets are a tube type tire, but many also run these without tubes. They will work fine without, but may need more frequent air pressure adjustments. I've run them both ways without problem.
Old Dec 27, 2005 | 10:58 PM
I run tubeless Moroso DS-2's on the front with 15x3.5" Pro-Stars, and have run both Hoosier QTP's tubeless, and ET Drags with tubes on my 15x10" Pro-Stars, also with no problems.
Old Dec 28, 2005 | 08:01 AM
Javier97Z28's Avatar
I've been running ET Streets now in 26 x 10.5 x 16 for 2 years now w/o tubes, no problems, hardly any air loss over time.
Old Dec 28, 2005 | 01:48 PM
RamAir95TA's Avatar
Thank you for the replies. Looks like I will be using the tubes!
football4life
Oct 4, 2015 07:48 AM
drt
Sep 27, 2015 04:39 PM
4586
Aug 22, 2015 01:09 AM
4586
Aug 18, 2015 07:08 AM
CARiD
Exhaust System
Aug 3, 2015 05:10 AM
