Fuel question
Old Dec 26, 2005 | 11:53 PM
walt355's Avatar
Fuel question
Is a Walboro 255 good enought for a 250 shot with no Booster pump or anythinglikethat?
Old Dec 28, 2005 | 10:09 PM
walt355's Avatar
Re: Fuel question
anyone??
Old Dec 28, 2005 | 10:40 PM
Re: Fuel question
What is the "total" HP of the engine..... NA + N2O? Only with that info can you estimate the fuel requirements, and compare it to the flow curve for the pump in question. It would also be necessary to know the operating pressure for the fuel system if its anything other than 43.5psi.
Old Dec 29, 2005 | 08:23 AM
ejfagala's Avatar
Re: Fuel question
As long as you have the 255 in line it will only flow as much as the 255 can provide. THe booster pups such as the T-rex will add PSI but the system can only flow as much as the smallest pump can provide. As for if the 255 is enough pump it depends on what your total HP is. I think the 255 is good for around a total of 700CHP, do not quote me on this I am going off a poor and sometime troubled memory .
Old Dec 29, 2005 | 09:36 AM
walt355's Avatar
Re: Fuel question
Im not sure exactly wht fuel pressure Ill be reunning at yet. the car should make 425 WRHP NA and up tp a 250 shot is a shot as I will ever spray it.
Old Dec 29, 2005 | 11:56 PM
Re: Fuel question
What is the flywheel HP.... that's what determines the fuel requirements??? Making assumptions on your drivetrain losses, and allowing for a 20% return capacity at max flow, you would probably be looking at about 190lph for the NA portion, and maybe 130lph for the N2O, for a total of 320lph. A Walbro 255 will not be enough.
I run a 205lph Bosch pump in the stock tank location for "NA" power, similar to what you are looking at, and have a 2nd 205lph Bosch pump off a sump on the rear of the tank. The second pump only comes on when the nitrous system (300HP) is armed. The two pumps flow in parallel, merging in a "Y" right in front of the fuel filter.
You can increase both the flow and pressure capability of a fuel system by putting pumps in series. The actual flow vs. pressure curve will be a summation of the two individual pump curves, and each one will reach an equilibrium point at which both pumps flow the same, but contribute a portion of the total pressure based on their individual flow curves. Since the smaller pump is now operating at a lower differential pressure, it is capable of flowing more capacity than when it was supplying the full pressure of the system.
I wouldn't recommend series pumps as a way to increase system capacity, but it is possible. Best used for systems that also require higher pressure, like a blower using an FMU, or a dry nitrous system like the NOS 5176.
Old Dec 30, 2005 | 05:00 AM
LameRandomName's Avatar
Re: Fuel question
How do you keep the fuel from back feeding?
Old Dec 30, 2005 | 11:11 PM
Re: Fuel question
Kinsler #3096 bubble tight check valve, -6AN.
Deadbolt24
Jan 19, 2015 01:29 PM
nophix
Nov 30, 2014 10:26 PM
guionM
9
Aug 29, 2002 01:48 PM
dansam
Jul 20, 2002 01:10 PM
