My Iroc is catching smoke
Old Dec 24, 2005 | 03:29 AM
Solidous_Snake's Avatar
Unhappy My Iroc is catching smoke
I need some help with this. If the cars been sitting for awhile the coolant tank will show its completely empty, but after 20 mintures of driving it there will literally be smoke coming out through the hood. The smoke comes from the coolant tank reservoir. The coolant will bubble up all the way to the top as if I was boiling water over a pan. Today I saw the same thing, but coolant was also spraying out of the radiator cap real violently. There's coolant all over the engine bay. This might be worth mentioning, I had a mechanic just recently put in a new 5.7 engine into the Iroc in question. Any suggestions?
Old Dec 24, 2005 | 07:42 AM
blown3rdgen's Avatar
Re: My Iroc is catching smoke
possible head gasket? Maybe due a cyl leak down test or cooloant system pressure check.
Matt
Old Dec 24, 2005 | 07:44 AM
Jim D's Avatar
It sounds to me like there is a hole/crack somewhere in the block that let's the combustion relieve itself into your coolant system instead of just when the exhaust vavles open. Or it could be a crack/hole in your heads doing that too...Or maybe a head gasket leak...hopefully just a head gasket leak.
Good luck!
Old Dec 24, 2005 | 07:10 PM
89_Irocz's Avatar
Take out the thermostat and see if it still does it. If you had a crack in the block or something like that then steem would be comeing from there. If it was a blown head gasket the you may the water in the oil witch will look kinda white, or you will be blowing white smoke (steem) from the tailpipe.
Old Dec 24, 2005 | 11:21 PM
The engine before this one had a blown head gasket and a cracked engine core. This new engine is sharing all the parts from the old engine. I forgot to mention that it's consuming a crazy amount of gas. I went from 3/4 tank to 1/8 tank in 20 miles.I just want to know why is my coolant boiling hot and what's with the gas mileage?
Old Dec 25, 2005 | 02:50 PM
89_Irocz's Avatar
Well the gas thing maybe be just a bad gauge, a common problem in the 3rd gen camaros. Did you use the old water pump? If so that may caused the problems with the old block and will cause it with this one.
Old Dec 27, 2005 | 02:18 AM
I think it was a loose radiator cap the whole time. I'm still not sure, but the smoke hasn't occured yet since. Maybe I'm really low on coolant or something since most of it leaked out, but I'll check it out tomorrow.
Old Dec 28, 2005 | 10:46 PM
Yossarian14's Avatar
Loose radiator cap causing that much smoking really? Unless it was splashing on to the hot engine block and burning Im a little confused.
Old Dec 29, 2005 | 08:29 AM
89_Irocz's Avatar
Having a loose cap is like having a bad one. It will cause the car to over heat.
RX Speed Works
Sep 11, 2015 03:31 PM
jackpawt883
Sep 10, 2015 08:53 PM
gonzo275rltw
Sep 7, 2015 04:46 PM
gonzo275rltw
Sep 5, 2015 06:26 PM
gonzo275rltw
Sep 5, 2015 06:24 PM
