standard up keep
Old Dec 11, 2005 | 01:25 AM
simplegt's Avatar
standard up keep
gonna buy a used 1993 camaro for 3,000 has 115,000 miles what should i be looking for and what should do first when i get it. besides oil, brakes and tune up
Old Dec 11, 2005 | 07:15 AM
Dave89IROC's Avatar
Re: standard up keep
check/replace all fluids, belt(inspect), hoses(inspect)
other then that, it may or may not need an opti soon
Old Dec 11, 2005 | 08:42 AM
simplegt's Avatar
what is a opti
Old Dec 11, 2005 | 10:37 AM
The OptiSpark is the front-mounted ignition distributor on an LT1 engine. They either wear out, or get damaged when they get wet, even from a from drips off the weep holes of the water pump, which is directly above the distributor.
Some last close to 200K miles, others fail in a few thousand. One caution - do not under any circumstances attempt to wash down, pressure wash or steam clean the engine. That may cause almost instantaneous destruction of the Opti.
cmsmith
Sep 14, 2015 09:25 PM
heus
Sep 8, 2015 12:01 PM
97blackformula
Aug 27, 2015 06:02 PM
detroitmuscle
Jul 31, 2015 04:21 AM
tbyrne
Jul 2, 2002 05:37 PM
