New ATI 4.5" twin intercoolers
Old Dec 3, 2005 | 01:35 PM
David94TA's Avatar
Anybody tried these yet?
Twin Highflow 11L x 9W x 4.5D
Fit? Efficiency? How much better flow than the previous 11 X 9 X 3"?
I've read past posts where many people feel like the previous twinflows were restrictive--seems like adding 1.5" to the depth would increase the volume substantially. It also appears that they went from a 2.5" inlet to a 3.0" diameter.
Old Dec 5, 2005 | 04:58 PM
David94TA's Avatar
Re: New ATI 4.5" twin intercoolers
Called ATI today--unfortunately the 4.5" deep won't fit our cars. Not enough room they said.
Old Dec 5, 2005 | 09:20 PM
ZBLKHELLRZR's Avatar
What?! Are you sure? Man that would suck but maybe he didn't know what he was talking about perhaps? Somebody has to have them on their car by now. I'd call Bob @ EPP and see what he says. I don't have mine yet so I can't say whether they do or don't but it seems there is room but a TA my be different than a Z too so who knows. Wish somebody w/ the old twin IC's would chime in and see if they think there is room for more.
That really blows chunks if they don't fit.
Old Dec 5, 2005 | 09:28 PM
LittleRedZ's Avatar
tight fit here with old twins
Old Dec 6, 2005 | 12:01 AM
Kredz28's Avatar
yea they are a tight fit...i could see how it would be tricky...heres a couple pics of my 3.5's. you be the judge
The November 2005 GM High Tech Performance tested the new 4.5 inchers on an ls1 TA and compared them to the 3.5 inchers...they found .5 psi less boost drop off and 10% more effective in cooling air. They found a 9 degree difference in IAT from the 4.5's over the 3.5's. I believe at 6500 rpm the 4.5's were sitting at 62 degrees, compared to 71 for the 3.5's...hope this helps
Old Dec 6, 2005 | 12:14 AM
Maybe there is a way it can be modified to fit? May need a little cutting of the bottom where the IC is? I don't know but is there more room at the top vs how it looks really close at the bottom w/ no clearance.
Now I wonder if ATI sells the 4.5" version for Fbodies and lists "modification required to fit".
Old Dec 6, 2005 | 08:16 AM
1SlowFormula's Avatar
So if they got it to fit for the test then there is a way right???
Old Dec 6, 2005 | 09:25 AM
LittleRedZ's Avatar
ls1 front has more room under there, lt1s are very narrow and thin
Old Dec 6, 2005 | 03:45 PM
Ponyhntr's Avatar
The 4.5" twins are for the LS1 Cars. They will not fit the LT1's. I have tried to make them work, but they just won't. Even with custom-fabbed tanks they won't work.
We LT1 guys are stuck with the 3.5".
Old Dec 6, 2005 | 07:44 PM
INTMD8's Avatar
From: I reached back like a pimp and smacked that LS1....
When I measured up my car it seemed like their was much more room standing the IC's up vertically. The cores on these are 15x6x4.2
Not sure if these will fit a pontiac.
http://www.ls1speed.com/artwork/intmd8/large/040.jpg
http://www.ls1speed.com/artwork/intmd8/large/042.jpg
http://www.ls1speed.com/artwork/intmd8/large/043.jpg
http://www.ls1speed.com/artwork/intmd8/large/041.jpg
http://www.ls1speed.com/artwork/intmd8/large/023.jpg
http://www.ls1speed.com/artwork/intmd8/large/022.jpg
Old Dec 8, 2005 | 09:46 PM
ramair96ws6's Avatar
you could always go this route
Old Jan 29, 2006 | 09:31 PM
snorkelface's Avatar
What intercoolers are you using on your setup?
Old Jan 29, 2006 | 10:08 PM
96speed's Avatar
At this point, everything is "custom." I'm sure there is a market for off the shelf stuff, though.
Custom = measuring tape, and sore back .
Ryan
Old Jan 29, 2006 | 10:39 PM
INTMD8's Avatar
They were made to my spec's by Griffin. I've got 2 more sitting on the shelf.
Old Jan 31, 2006 | 02:35 PM
blown383's Avatar
2 questions
1) How much?
2) Where did you mount?
-B
Mar 13, 2016 03:37 PM
bunker
Jan 30, 2016 08:09 PM
brothaslide
Jan 9, 2016 12:11 PM
LeftoverChinese
Jul 23, 2015 03:57 PM
