NGK iridium plugs are fine for a supercharger right?
Old Nov 15, 2005 | 04:16 PM
Justin96'WS6's Avatar
I am putting on my D1SC this weekend, on my LT1 i just put these direct replacement ngk iridium's in last month, or should i go with a tr6?? Thanks
Old Nov 15, 2005 | 09:30 PM
Kredz28's Avatar
Re: NGK iridium plugs are fine for a supercharger right?
I would definitley switch to the tr6 especially if you are stock internally. They are a heat range colder to help you stay out of detonation...go grab some...they are like 2 bux a piece.
Old Nov 17, 2005 | 06:07 AM
2NastyZ's Avatar
I can't say about supercharging but I can sure tell you there not worth a darn in a turbocharged car. Stay with the TR6
Old Nov 17, 2005 | 09:00 AM
RCF925's Avatar
I use the TR6's, I would stay away from the Iridium or any platinum plug for blown application
Old Nov 17, 2005 | 09:18 AM
markinkc69z's Avatar
You don't want to run any kind of plug that has a grounding pad spot welded to the ground strap(s). Many of the newer "precious metal" plugs have these pads. They could come off in a supercharged application. One heat range cooler than stock, just your basic resistor plug, should get the job done in a street setup up to 12 pounds or so.
Old Nov 18, 2005 | 03:48 PM
Ultra_Dog's Avatar
TR6, NGK Iridium, Autolite 103, etc.
My car could care less. They all work, none seem to make a difference. My problem needed programming and DELTEC!!!
Gapped at .030. no improvement, no decrease. Just a lot of headache to change them.
ATI #8PSI, 383 with -31cc JEs.
HarleyZ28
Oct 5, 2015 06:23 AM
nikko
Apr 20, 2015 07:56 AM
racecarz28
Mar 30, 2015 09:55 PM
SC97TA
Sep 15, 2002 01:10 AM
ferraricameron
Jul 29, 2002 07:46 PM
