Rearend question
Old Oct 24, 2005 | 11:12 PM
Notacamaro's Avatar
Rearend question
According to the code in my glovebox, my 95 Z28 has 2.73 gears. What all do I have to change to put 3.73's in it. I need a different carrier don't I?
Old Oct 25, 2005 | 04:49 AM
anaik's Avatar
Re: Rearend question
You can get 3.73's for the 2 series carrier. Check the Supporting Vendor Index. Summit and Jegs also sell them. If you have a lot of miles, it might be wise to replace or rebuild the posi carrier. You should have an Auburn. The company has an exchange program where they rebuild it for about $100.
Old Oct 25, 2005 | 11:14 AM
Notacamaro's Avatar
Ok, great. I have some 3.42 gears out of my s-10. Do you think it will make a big enoguh difference to bother putting them in there?
Old Oct 25, 2005 | 12:31 PM
anaik's Avatar
If the gears out of the S-10 are GM they are 3 series and won't work without a spacer, not a good idea, I've heard.
3.42's will make a difference, a 25% increase in torque.
Old Oct 25, 2005 | 05:30 PM
Notacamaro's Avatar
So I guess I'll go with some 3.73's for the #2 carrier. Thanks for the help man.
Old Oct 26, 2005 | 07:35 AM
LWillmann's Avatar
I've only seen two S10 rear ends, and they were both 8.5" ring gears, so you might want to be sure you're dealing with the right size gears.
Old Oct 26, 2005 | 08:08 AM
anaik's Avatar
Where these out of the ZR2. I have a '98 S-10, and the factory brochure says the ZR2 has a widened frame and a 8.5" ring gear in the rear axle. leading me to believe the other models have the 7.5".
Old Oct 26, 2005 | 10:55 AM
LWillmann's Avatar
One of them was a fleet (straight) side, 2.2L 4-cylinder with 5 speed manual trans. I don't know if it was a ZR2. The other I'm not sure, it was already out of the truck.
Old Mar 21, 2006 | 08:38 PM
chestnuthillfrog's Avatar
how do u get the code info to tell what rearend in a car?
Old Mar 22, 2006 | 06:06 AM
anaik's Avatar
'95 and earlier, the codes are on the inside of the glove box lid. They are,
GU2=2.73
GU5=3.23
GU6=3.42
'96 and up are on the inside of the drivers side door.
Not positive about the years and their location of the RPO list, but it's in one of those places.
blac94Z
29
Mar 25, 2015 04:21 PM
ddr698
Jan 31, 2015 10:58 AM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
ddr698
Jan 9, 2015 10:05 AM
Speeds8erM-1
Jul 28, 2002 06:18 PM
