Home Depot Brand Subframe Connectors
Old Oct 25, 2002 | 03:33 PM
pillagenburn's Avatar
Anyone gone to Home Depot and gotten a bunch of tubular steel rods, taken them to a muffler shop and had them fit and weld the rods up to your camaro/transam ?
If so, how well did it work/not worK?
thanks!
Old Oct 25, 2002 | 08:35 PM
LPEdave's Avatar
I suppose it could work, but I can't imagine it would be cheaper than buying a set for $100...
Dave
Old Oct 25, 2002 | 10:15 PM
chuck's Avatar
Wolfw Racecraft SFC's are a great bargain on a great part!
Old Oct 26, 2002 | 01:05 PM
blksgZ28's Avatar
i've never seen wolf racecraft subframe connectors? they don't have them on their page, have any pics?
Old Oct 28, 2002 | 08:14 AM
teke184's Avatar
or BMR for $139...with your choice of color...lol
Old Oct 30, 2002 | 08:03 AM
Norm Peterson's Avatar
The only way I can think it would be cheaper to custom-fab them is if you can do it all yourself. Engineering, cutting, fitting, welding. And cheaper is only if you charge yourself a $0.xx labor rate.
But if you insist, or wish to do it up in some slightly different way than any aftermarket supplier has to date, go to a steel shop that will deal in small quantities. You will get a much wider variety of tubing sizes and thicknesses, not to mention a better price. Been down this road, sort of . . .
Norm
Old Nov 2, 2002 | 05:52 PM
Thomash's Avatar
I bought the KBDDs and I'm a tight a$$. I made my brake ducts out of shop vac parts
Old Nov 2, 2002 | 08:12 PM
Dr.Mudge's Avatar
Tube and sheet metal stock isn't all that cheap, when your only buying small amounts, so it would not likely save you very much, plus then you have to do it right.
If you buy all boxed metal stock, it will probably be easier to put together.
Old Nov 4, 2002 | 11:12 AM
MustangEater82's Avatar
I would make sure the stuff you buy form home depot is also as sturdy and as thick as any subframes you buy.
HOFFICER
Apr 6, 2020 10:36 AM
May 25, 2016 08:10 PM
Mar 13, 2016 03:39 PM
QuickSilver02
Apr 7, 2015 11:12 AM
