Anyone have the Delalum front lca bearings from Global West?
from their site...
Front lower control arm spherical bearing kit (fits 1993-2002): New
One of the biggest complaints we hear from Camaro and Firebird owners is the deflection in the front lower control arm bushings. The control arm bushings deflect allowing the lower control arm to pivot in or out depending on the load. This in turn changes the alignment while the load is applied. Handling and performance are reduced.
Benefits and Features:
Bearing kit replaces the factory bushings.
Spherical aircraft bearings allow smooth movement without bind.
Bearings are Teflon lined so no grease fittings are needed.
Kit controls alignment providing improved response and vehicle control.
Maintains correct control arm length.
Part# SP-7 Price $331.25
We used those and a set of the GW upper a-arms on one of my co-workers '93 Z28. All I can say is OH MY GOD. That car turns in HARD now.
I will warn you, there is a lot more road noise transmitted through the car.
carguyshu
Jan 22, 2017 11:19 AM
PublicEnemy1
Apr 7, 2015 12:21 PM
