rotars on a 4th gen?
Old Sep 14, 2005 | 10:10 PM
Midnight93Z's Avatar
should rotars from a late 4th gen 98+ fit on any yr 4th gen? am i gona need 98+ calipers? thanks
Old Sep 14, 2005 | 10:45 PM
WestCoast96Z28's Avatar
Re: rotars on a 4th gen?
No. 93-97 LT1s have different front and rear rotors than the 98-02 LS1s. Yes, you will need 98+ (aka LS1 rotors...and other parts) if you're planning to installing into an LT1 car.
What you're talking about is an LS1 brake upgrade. Try a search for this and you'll see plenty of posts about what parts are needed, how to do the upgrade, and where to buy used/new parts.
Red96Lt1's Avatar
98+ are 12 inch. 93-97 are 10.5 inch
Old Sep 18, 2005 | 06:37 PM
Severous01's Avatar
dude, first off, ROTOR...not rotar. secondly, ebay would probably be the best bet (unless you know someon who owns a junk yard) for the complete setup for the 98+ brake upgrade. it comes with the rotors, calipers, spindles, even the bearings. just take off the spindle as a whole from your lt1 car and put on the spindle as a whole from the 98+ car. really simple. but you're going to need an alignment if you do so.
the 98+ unit costs about 150-300, depending on where you go and who wants them at the time (ebay usually gets about 200). but if you want some real brakes there is the 97+ corvette brake upgrade that is fairly cheap for what you get. mounting brackets, pads, pad brackets, hoses, all for about 600-700 from lgmotorsports.com (98+ section, brakes). i would suggest this if you want better brakes. yeah it's overkill, but i think it's necessary overkill with these cars. especially if you plan on doing any serious power upgrades on the car.
Old Sep 20, 2005 | 12:23 AM
Mr. Merk's Avatar
so when my girlfriend converts her 95 V6 to 98+ discs, she just needs the front spindles, and the rear axle assembly? we found a 98+ V6 already
she's also wanting a posi diff and lower gears...we can do that seperately
is the master cyl the same?? what about the rear brake lines??
Old Sep 30, 2005 | 06:43 PM
Severous01's Avatar
all you need to change is the spindles, you dont need anything esle. there are so many threads on this...
if you want to get a posi rear, you'll have to pull it off a z or forumla/ta. they came from the factory. if she has an auto and wants some serious torque, get the rear from a manual car. 3.42 gears are awesome for a auto car.
Old Sep 30, 2005 | 11:46 PM
Z95m6's Avatar
If you want to do the rear brakes you will need to get the axles out of a 98+ car. If you can find 93-97 rear disc brakes just get them as they are just as good as the 98+
Old Oct 1, 2005 | 06:04 PM
Mr. Merk's Avatar
getting EVERYTHING from a 98SS
David Dempsey
Mar 12, 2016 12:42 AM
HAWG
Sep 25, 2015 11:41 AM
Fatdog2
Sep 16, 2015 11:04 PM
