Amp For JL 10w6
Old Aug 31, 2005 | 05:03 PM
slayer6x6's Avatar
Amp For JL 10w6
Im about to buy a JL 10w6 in a stealth box for my car. Can somebody recommend an amp that will power this sub to its full potential?
Old Sep 1, 2005 | 07:56 AM
LS1 RULZ's Avatar
Re: Amp For JL 10w6
Get a quality name-brand amp (NOT Pyramid, Kenford, Rockwood, etc.) that puts out as many Class-D watts as you can afford. I would recommend at least 300W RMS.
Old Sep 1, 2005 | 09:23 AM
PentaVolvo's Avatar
Re: Amp For JL 10w6
is that sub a Dual 2ohm or a Dual 4ohm sub. If its a dual D4 which i think it is you want a monoblock amp that can do around 400rms. For example http://sonicelectronix.com/item_2747.html is a nice phonenix gold, this would be an extremely nice amp http://www.cardomain.com/item/POLC5001 although i think its over priced. JL also makes nice amps. There is tons of other stuff out there
Old Sep 1, 2005 | 09:56 AM
slayer6x6's Avatar
Re: Amp For JL 10w6
I was just looking around on ebay. The JL 500/1 looks like it would go good with the W6.
Old Sep 1, 2005 | 10:18 AM
PentaVolvo's Avatar
Re: Amp For JL 10w6
deff would
Old Sep 7, 2005 | 08:42 AM
cndctrdj's Avatar
Re: Amp For JL 10w6
i use the jl 250/1 it is plenty loud and very clean... and not too costly
Old Sep 7, 2005 | 02:43 PM
kandied91z's Avatar
Re: Amp For JL 10w6
for only 1 almost anything. unless your getting a deal in all honesty i'd go with whatever fits in your budget. i ran them with pioneer premier and also two different ppi amps with very good luck but i ran 3 of them at the same time. for the most part an amp is an amp, just get what you can afford and check the specs. class d is definately a good way to go.
Mar 13, 2016 03:37 PM
HibachiZ28
Nov 6, 2015 12:53 AM
Bobczar
Oct 23, 2015 11:22 AM
secbase8
Parts Wanted
Sep 8, 2015 07:11 PM
NewsBot
Jan 8, 2015 11:29 PM
