Weight of my car
Old Aug 27, 2005 | 02:21 PM
scmudslinger's Avatar
Weight of my car
I have a '93 Z28 w/ Automatic Transmission. Is there a good place to find out what the weight of it is?
Old Aug 27, 2005 | 02:34 PM
jfischer's Avatar
Re: Weight of my car
Roughly 3,400 pounds or so if I recall correctly.
Old Aug 27, 2005 | 02:38 PM
flatlander757's Avatar
would a '94 be about the same? with all power options...
Old Aug 27, 2005 | 02:45 PM
Go to the bottom of this page for the "factory" weights, including some options:
http://www.f-body.org/tech/tech.htm#FourthGen
Old Aug 27, 2005 | 03:31 PM
Thanks for the help, guys
Old Aug 27, 2005 | 07:49 PM
2000GTP's Avatar
That was a very helpful link, thank you as well.
Old Aug 28, 2005 | 03:44 AM
Johnnynsac's Avatar
The only real way is to go weigh the car yourself. You can have two Camaro's with the exact same options and one might weight 100 pounds (give or take) more then the other. Thats GM for you.
Old Aug 28, 2005 | 09:36 AM
jfischer's Avatar
Yeah, maybe if one had an empty gas tank and one was full
Old Aug 29, 2005 | 05:14 PM
Paul N's Avatar
My 97 was 3408lbs with a half tank of gas, manual trans and loaded with t-tops. Weighed it on a truck scale a few weeks ago.
Old Sep 16, 2005 | 06:25 AM
FNDRB58's Avatar
Camarosource.com has different numbers....
oldschool
Feb 9, 2016 09:21 PM
bossco
Nov 29, 2014 10:18 AM
USAirman93
Nov 24, 2014 03:37 PM
wytblur
Mar 2, 2003 03:40 PM
sleeperZ96BT
Aug 29, 2002 01:10 AM
