sub frames
Old Aug 22, 2005 | 06:35 PM
lt1street's Avatar
sub frames
weld in or bolt in???
Old Aug 22, 2005 | 09:29 PM
Showme's Avatar
Re: sub frames
Weld-In
-Tim
Old Aug 22, 2005 | 10:39 PM
goosechevy21's Avatar
Re: sub frames
Another vote for the weld-on type.
Over time, the holes drilled for the bolt-on style will enlarge and allow some play between the SFC's and the actual subframe.
Old Aug 23, 2005 | 06:33 AM
teke184's Avatar
Re: sub frames
the very purpose of the SFC is to stiffen the chassis.
on that note, why would you want a set that has an obvious point of flex?
weld in
Old Aug 23, 2005 | 09:51 AM
87DJP2001's Avatar
Re: sub frames
Don't even think of bolt on SFCs unless you are going to weld them in at the time of installation. Otherwise don't waste your money / time on bolt in SFCs.
Welded on SFCs are the best improvement you can make to tighten up any Camaro/Firebird any model or engine option.
Old Aug 23, 2005 | 08:31 PM
hazard2k's Avatar
Re: sub frames
going on with this post, would you recommend the single bar type or the triangle shaped ones? Is there that much of a difference?
Old Aug 23, 2005 | 08:34 PM
Z95m6's Avatar
Re: sub frames
Weld in. If these cars were super rare i would probably say bolt in but on these cars it doesn't matter. Maybe a LT4 SS or something bolt in would be the way to go.
football4life
Oct 4, 2015 07:48 AM
Daluchman1974
Sep 11, 2015 06:12 AM
4586
Aug 22, 2015 01:09 AM
4586
Aug 18, 2015 07:08 AM
Aug 5, 2015 08:35 AM
