Drivers window wont go up (all of a sudden) NEED HELP BAD!
Old Aug 4, 2005 | 10:52 PM
BlackLT1_TX's Avatar
Well, tonight as I pulled up to my destination I went to roll up the windows and only the passenger side would go up. The drives side wouldnt do anything. I have replaced both the motors within a year or so, and up until this they have worked flawlessly. I am wondering what I can do to jump the switch, to rule that out, although I think it might be the motor since the breaker got warm as I kept hitting the drivers window switch up and down over and over.
Any ideas?
-James
btw- this is going to be a big problem tomrrow as i cant leave the car parked with the window down.
Old Aug 5, 2005 | 11:05 PM
Spllouder's Avatar
Re: Drivers window wont go up (all of a sudden) NEED HELP BAD!
you are going to have to open up the door and test the motor with a ohm meter or run some wires from the battery or under the dash and manully test the motor , i would test the motor and see if it has any ohm's if it does it should still work .
most new W.M. has lifetime gauuretes get it replaced .
Keenan
Jan 19, 2023 12:24 PM
dale3in98
Feb 14, 2015 12:18 PM
warmeck
Feb 2, 2015 12:44 AM
Fatdog2
Jan 24, 2015 12:08 AM
kizz
Jul 6, 2002 11:03 AM
