Help!!
Old Jul 27, 2005 | 08:33 PM
1crazylt1's Avatar
Help!!
ok so i was changing my crank n got 2 of the 3 screws out..the 3rd one stripped..how do i get this bolt out i need out with this one..
Old Jul 27, 2005 | 09:41 PM
Zero_to_69's Avatar
Re: Help!!
Channel locks
hammer on a smaller socket
die grind the edge of the bolt
Drill off the head, and use a strong plier to unscrew the 'stud' (if the bolt isn't counter sunk)...mabe even a reverse thread kit.
P.S. Let me be the first to say, this thread is getting moved faster than a
top fuel dragster at full throttle
Old Jul 27, 2005 | 10:12 PM
OldSStroker's Avatar
Re: Help!!
Drag it over to SLP. IThey're in your neighborhood, right?
Zero is correct. Try the specific forum for your engine. You'll probably get more responses there.
Old Jul 27, 2005 | 10:29 PM
aggiez28's Avatar
Re: Help!!
i think you have much more to worry abotu if your crank is held in by screws
Old Jul 27, 2005 | 10:48 PM
Zero_to_69's Avatar
Re: Help!!
Zero is correct.
I don't see that much from you in this forum. I better enjoy the glory while it lasts.
