Zero oil pressure, need some help
Old Jul 22, 2005 | 05:28 PM
FAST LS1's Avatar
*Update* Zero oil pressure, need some help
So the oil pressure guage is at zero.
When I'd take the key out of the ignition, the guage would rise to about 20-25psi, then as soon as I turn the key to run, it would drop to zero. I started it a 3-4 times all the while reading zero, and on the last try I heard ticking and turned it off and left it set.
Full of oil, I checked that the first time I cranked it, and it started and still read zero.
The fact the guage moved off of zero while setting makes me think it's not the guage, and the slight ticking on the last attempt is sickening. I probably should have said **** it and left it set the first time it read zero, but I was stubborn.
Leaving work the check guages light came on. I saw zero oil pressure, cut the engine instantly in the middle of the road. Stopped, checked, and started it back up and it read 40-45psi, so I thought the guage was just going out. Damnit.
So know to diagnose the problem, because from previous posts on the subject I know it could be any number of things.
1) Sending unit is bad. I haven't done an intake swap though to hurt this sensor.
2) Oil pump is bad
3) Spun bearing
I've posted this on a few boards, just trying to get some input by anyone who's been down this road, and knows first hand.
Any help is appriciated.
*UPDATE*
Installed a new oil pump and sending unit.
Old Jul 22, 2005 | 08:36 PM
1984camaroz28's Avatar
Re: Zero oil pressure, need some help
its the the sending unit or gauge u heard ticking that is ur lifeters ticking because there dry. ur oil pump probl took a crap
Old Jul 23, 2005 | 09:55 AM
Victory Racing's Avatar
You can test the oil pressure with a mechanical gauge. If you do not have access to one most Auto Zones have one they rent out.
Right above the oil filter on the side of the oil pan is where you connect the tester. That will give you the true oil pressure reading directly off the pump.
Old Jul 23, 2005 | 10:01 AM
FAST LS1's Avatar
Is there a tapped hole in the oil diverter plate?
I don't really want to have to tap and plug a hole just to mechanically test the pressure. That and I don't really want to turn the engine over any more if the pump has actually failed.
I think I'm going to drain the oil, and take off the filter to check them for any shavings.
Then try to test the oil sending unit with a multitester somehow.
Old Aug 8, 2005 | 07:04 PM
FAST LS1's Avatar
Updated first post.
HectorM52
Jul 30, 2017 11:46 AM
Nickster 7
May 1, 2015 09:04 PM
surreybrad
Apr 22, 2015 06:40 AM
KYWes
Apr 15, 2015 05:48 AM
ad356
Apr 11, 2015 08:49 AM
