Fuelie Heads
Old Jul 5, 2005 | 01:13 PM
ChrisUlrich's Avatar
Fuelie Heads
Ported and Polished with the XE 284 cam... whats you're take on this setup? Looking for a nasty lope/rumble?
LT's, x pipe, and... not sure of the catback
Old Jul 6, 2005 | 11:13 AM
Tru2Chevy's Avatar
Re: Fuelie Heads
That cam should give you a very nice sounding idle. I have the XE274, and it sounds pretty damn nice all warmed up and idling at 600RPM
- Justin
Old Jul 6, 2005 | 01:19 PM
LameRandomName's Avatar
Re: Fuelie Heads
Well, I've run a SIMILAR setup and I'll tell you that you will enjoy the combo. Nice lope and a strong puller up through the 6000+ range. Or at least the 280H cam I used was... that cam should actually be a little bit better.
However, head technology has come a long way and you can do better than Fuelie heads.
At the very least, send those heads to a porter with a good rep to let him do his thing. You're probably also going to want to mill them to reduce the combustion chamber size, even if it means running a dished piston; and if you're going to mill them then you may as well angle mill them. Of course, now you're starting to spend some money, but I thought you'd like to know.
Old Jul 6, 2005 | 01:32 PM
1quikZ's Avatar
Re: Fuelie Heads
I agree with "random" Id go for a bit newer head or atleast get them P&P, why not go with something like L98's or voretc heads?
Old Jul 6, 2005 | 02:24 PM
XcYZ's Avatar
Re: Fuelie Heads
FWIW, the X-pipe will mellow out the lope at idle.
Old Jul 6, 2005 | 09:17 PM
Re: Fuelie Heads
Really? Mellow out the lope?
Getting the Fuelie heads P&P for $250 from a good friend... thats why i'm going with them. Plus, the funds aren't there for aftermarket ones.
Old Jul 7, 2005 | 08:33 AM
XcYZ's Avatar
Re: Fuelie Heads
Yep, with one of my motors, I went from an H-pipe to an X-pipe, and the difference in how much less aggressive the idle sounded was dramatic. The headers and Flowmasters were the same, all the was changed was the swap from the H to the X.
While it mellowed out the idle considerably, it sounded great at WOT.
Old Jul 7, 2005 | 10:30 AM
Tru2Chevy's Avatar
Re: Fuelie Heads
Here is a short video of my 400 with the XE 274 (open headers): http://www.njfboa.org/JustinImages/400.MOV
Quality isn't great, but it will give you an idea.....
- Justin
Old Jul 7, 2005 | 07:59 PM
Re: Fuelie Heads
- Justin
What motor is that? I should of mentioned this is a 327
Old Jul 7, 2005 | 09:36 PM
1quikZ's Avatar
Re: Fuelie Heads
Wow, that is one lopey cam
Old Jul 11, 2005 | 01:15 PM
Tru2Chevy's Avatar
Re: Fuelie Heads
That is the XE 274 on a 400sbc with mildly ported vette L98s (more detail in the sig)
The XE 284 in a 327 will prolly have a lot more lope, as cubic inches tend to eat up a bit of lope. A buddy of mine had the XE 274 in a 350 with edelbrock performer heads in his '77 vette, and it sounded pretty nice through shorty headers and a crap exhaust with a pair of 40 series flowies on it.
- Justin
Victor Lamb
Aug 26, 2017 02:52 PM
Roadie
Feb 16, 2015 10:34 AM
NewsBot
Jan 29, 2015 07:10 PM
NewsBot
Dec 28, 2014 06:20 PM
