Cprrect me if i'm wrong on this compression ratio calculation
Based on my calulations, a stock bottom end (untouched block) and factory heads using the fel-Pro 1074 head gaskets will net me around 10.8 to 1 compression (.4 over the factory 10.4 to 1). I based these figures on a forum search and what I found. Is this correct?
Thanks in advance!
Thanks in advance!
Re: Cprrect me if i'm wrong on this compression ratio calculation
This is from a while back, but should help.
http://web.camaross.com/forums/showthread.php?t=265540
Nayr
Mar 3, 2023 08:34 PM
surreybrad
Sep 29, 2015 09:00 PM
