Stenod Performance Twin Buildup...Sooo Close!! (pictures within)
The only item left to go in the engine bay is the engine harness, which we're re-pining to a 99+ harness. All you will see in that harness is the injector wires, which we are running on the inside of the fuel rails.
Alternator relocated to the passanger side top. Tensioner is now where the alternator used to be
Coil packs are relocated to the trans tunnel just below the firewall
Trans cooler mounted behind bumper
The oil pan sits about 1.5" below the k-member. The 4" exhaust actually sits higher in the car than the oil pan.
The Rossler TH400 and Neil Chance converter now sit in place of the 6-speed! I know it was supposed to be a stick car still....but plans have now changed!!!
4" exhaust w/ a 4" Bullet, dumps right before the axle
Weldon 2025 pump mounted on custom rear bumper, inside rear bumper cover. Stock tank sumped
Stay tuned for more pictures and hopefully if all goes well tonight and this weekend a video of the first start and hopefully a little dyno footage monday night
Thanks Guys.
Kevin and the team.
Thanks Guys.
Kevin and the team.
Re: Stenod Performance Twin Buildup...Sooo Close!! (pictures within)
Originally Posted by Kevyn
That is fookin' sweet.
All the work I have seen from the Stenod crew so far has been pretty impressive. Nice job guys!
now i know for sure my car will be in the right hands when the time comes to have my cage welded up.great work you guys looks bad ***.
also disregard the sig. i got hacked by my buddy!
F'n1996Z28SS
Aug 23, 2023 11:19 PM
bossco
Nov 29, 2014 10:18 AM
