Question about t-rex pump for vortech and meth/alky
Old Jun 19, 2005 | 04:40 PM
wicked_95z's Avatar
If I go with say a racetronix pump will I still need the t-rex pump?
Secondly, what does meth or alky injection do for a boosted car? Is there a difference between the two? Does meth injection take the place of an intercooler?
Thanks
Old Jun 20, 2005 | 12:46 AM
Racetronix's Avatar
Re: Question about t-rex pump for vortech and meth/alky
Thanks
Do not place a T-Rex in-line with our pump. It will choke it as the T-Rex is only about 200 L/Hr. If you need an in-line booster pump you should consider the Walbro GSL392 which is 255 L/Hr HP.
Meth will pickup your HP considerably. Meth will cool your IAT like crazy and release more HP when it burns. Meth can be used in place of or to supplement an IC if required. Ideally it is best to have both Meth and an IC. If you don't have an IC and you are relying on the Meth to ward off detonation you had best have some safety features installed just in case the system fails or you forget to top off the tank.
Old Jun 20, 2005 | 05:20 AM
wicked_95z's Avatar
hey...just the guys I was looking for. Do you know of anyone having some sort of deal or discount on your pumps and injectors right now? I'm looking for a plug and play pump and some 42 #'ers
Old Jun 20, 2005 | 07:06 AM
rskrause's Avatar
I don't run an IC, just water/alcohol injection. It works.
Rich
onefastgta
Mar 19, 2015 10:10 AM
Dec 17, 2014 11:00 AM
pologreen97z
Dec 2, 2014 10:42 AM
Carson96Z28
Aug 28, 2002 05:23 PM
dansam
Jul 20, 2002 01:10 PM
