98+ Camaro HVAC knobs in 97+ Bird?
Old Jun 18, 2005 | 07:34 AM
Camarocracy's Avatar
98+ Camaro HVAC ***** in 97+ Bird?
Does anyone know if the black HVAC ***** from a 98+ Camaro will fit in a 97 Bird? I just like the look of the black ***** over the gray ones.
Old Jun 18, 2005 | 10:26 PM
Re: 98+ Camaro HVAC ***** in 97+ Bird?
Also, does anyone know if that defrost button is removable? Or should I just get the whole HVAC pod?
Old Jun 19, 2005 | 05:19 AM
ubiquitus's Avatar
No, the button's not removable, but you can take it all apart. If you remove it, you have to take out the entire circuit board, clear plastic behind it for the led, and button cover, plus make something to hold it all again. I'd just get another HVAC pod. You can most likely pick one up for around $20 at a junk yard. I have a custom radio bezel/HVAC plate and wanted to add the defrost button, but decided to just screw it and not have one cuz it was too much trouble.
DrMilhouse
Oct 2, 2002 05:03 PM
AW/whiteZ-28
Aug 27, 2002 12:53 AM
turbo_Z
Aug 19, 2002 10:50 PM
Burn_Out
Aug 18, 2002 08:49 AM
Geoff Chadwick
Jul 31, 2002 12:07 PM
