Adding Zexel to non-posi rear
Old Oct 19, 2002 | 11:24 AM
94-3.4's Avatar
When the lt1 goes in this winter i still have my 323 open differential rear end in my camaro. Is it easy to add a zexel torsen or do i have to rip everything apart and may as well add some gears too. W
What do you think a open diff will do with 400hp?
Old Oct 19, 2002 | 12:08 PM
nikkev's Avatar
Cool
It's EASY to install a posi.
http://www.fastblackcar.com/camaro/lsd.htm
And with 3.23 gears you already have a 3 series carrier.So if 3.23's are a big enough gear for you then you're looking at about 2 hours worth of work in your driveway.Good luck.
Kevin
Old Oct 19, 2002 | 12:18 PM
94-3.4's Avatar
That seems easy enough. I think those 323 will work pretty good with a high stall tc. I still want to get some traction. Maybe i will leave the drum brakes on for the full sleeper effect
F'n1996Z28SS
Aug 23, 2023 11:19 PM
HectorM52
Jul 30, 2017 11:46 AM
Fastbird93
Apr 9, 2016 07:01 PM
QuickSilver02
Apr 7, 2015 11:12 AM
z28projects4ever
133
Jul 26, 2002 01:54 AM
