part number for aimco's slotted rotors at autozone??
Old Jun 11, 2005 | 10:02 PM
SOLO Z's Avatar
Angry part number for aimco's slotted rotors at autozone??
I'm in bad need for rotors and I wanted 2 go the right way and get the slotted over the stockers. But they didn't have it in stock and couldn't even pull it the computer. So anyone out there with their drilled rotor please give me the number so I can be done with these people
Old Jun 12, 2005 | 02:54 AM
SOLO Z's Avatar
Question ?????
Noone out there has these?
Old Jun 12, 2005 | 03:18 PM
revtime's Avatar
Re: part number for aimco's slotted rotors at autozone??
I have em but I could not tell you the part number.
It should come up on the computer at autozone when you bring up front or rear brake rotors for a 94 Z28.
Its possible they may not be carrying them anymore, mine are 2 years old.
Old Jun 12, 2005 | 07:58 PM
Fbodyboy1994's Avatar
i'll take a look for you tomorrow(i work at autozone)
Old Mar 13, 2006 | 10:51 PM
s2k's Avatar
s2k
The part number for the fronts are 55014 and for the rears are 55027. I got mines at Metal master rotors for 160.00. They're in California, if you want the number I can get it for you
Old Mar 14, 2006 | 07:27 AM
Greed4Speed's Avatar
If you want to do it the right way just get some blanks that are heavier than your stocker. From my experience a good blank should weigh from 18-19lbs. Stock front rotors are 16 lbs.
Slots and cross drills are for looks.
While talking about the right way, chose a better pad and get some fresh brake fluid in the lines.
Old Mar 15, 2006 | 03:59 AM
Black9TA8's Avatar
Why go heavier?
Old Mar 15, 2006 | 07:31 AM
Because rotors are a heat sink. More mass means it takes more heat (read friction) at longer durations for them to get to a given temp. If they have less mass it takes less heat at shorter durations to get them at the same temp.
In simple terms, they take more heat before they overheat or transfer the heat to the pads causing them to fade and the fluid to boil. They're also less prone to warpage. The stock rotors are 16 lbs. Think how crappy they are.
Good stock replacements 18-19lbs, stock sized Brembo 19lbs, stock sized Baer over 20lbs. See where this is going?
Now lets say you x-drill. You have now lost not only surface area for the pads to grab but mass while creating nice stress points for fractures to form.
GigaMp3z
Feb 20, 2003 02:57 PM
Wilson
Jul 21, 2002 05:08 PM
Wilson
Jul 21, 2002 04:58 PM
