Starting problem
Old May 24, 2005 | 07:37 PM
chevy87z28's Avatar
Starting problem
My 87 camaro has recently died a few times and can't starp up again unless it is jumped. However the battery is fine and the alternator also works? DOes this sound like a starter or something else? Along with what would be a good starter to get?
Old May 24, 2005 | 08:00 PM
91-Z28-L98's Avatar
Re: Starting problem
If the car is cranking but not starting, then its not your starter/batter/alternator. If it is not cranking and you are sure those 3 are good, then you either have a bad ignition switch or bad wiring somewhere. Since getting a jump seems to work, your problem is almost certainly the battery or alternator. Check connections to both. Make sure all terminals are clean and are properly connected. This may fix your problem.
Old May 24, 2005 | 11:30 PM
89_Irocz's Avatar
Is there a clicking sound or anything????
Alex Barnes
Jan 24, 2015 10:21 PM
Oncomingstorm22
Jan 22, 2015 07:15 PM
HCz28
Jan 11, 2015 11:21 AM
97z28k&N
Jan 9, 2015 04:58 AM
97SSdude
Dec 31, 2014 07:43 PM
