advice on fuel pump...
Old May 23, 2005 | 05:24 PM
whitelightning782's Avatar
Hey I have an 84 Buick Regal with a 355 in it. I am going to probably be looking at mid to high 12's and my fuel pump went out, I was wondering if you guys had any recommendations, it would be an in-tank fuel pump.
Old May 24, 2005 | 11:54 AM
Z28SORR's Avatar
Re: advice on fuel pump...
Carb or TBI/TPI?
Old May 24, 2005 | 04:37 PM
it has a carb
Old May 24, 2005 | 04:48 PM
Zero_to_69's Avatar
I would suggest a Holley Blue (or equiv.) with regulator for flow requirements.
Not sure about the in-tank model however.
110 gal./hr. would be the minimum flow I would think.
Old May 24, 2005 | 06:27 PM
alright, thanks. In the long term I would like to have a 100 shot of NOS, should I go ahead and get a better one now or would the one you reccomended be good enough for it? if it's possible I am going to convert it to an external one. do you know what all that would involve? or if it would be worth it.
Old May 24, 2005 | 08:34 PM
Zero_to_69's Avatar
I would suggest an external unit. It makes for easy servicing if you need to
swap, or modify.
With 100 shot of nitrous, I'd think that's borderline for a dedicated pump.
I'll leave that for the nitrous tuners.
Old May 25, 2005 | 05:07 PM
the current plan is to put a 15 gallon fuel cell in the trunk and use an external unit, so if something were to go wrong with it, it would be easy to swap out or work on. I think I'm going to go with the blue pump. thanks for the advice
Old May 25, 2005 | 05:46 PM
markinkc69z's Avatar
Our 11203 pump is an external vane style pump that is quieter than the holley and will flow at least 90 gph @ 10psi. Even more at carb or nitrous enrichment pressure. If for any reason you wish to have our pump serviced we offer that as well over its lifetime. The warranty is 1 year.
http://216.242.145.16/products/product.phtml?p=7
Jun 6, 2015 08:27 AM
jj_burchiel
Mar 5, 2015 07:05 AM
cmyname1
Feb 16, 2015 08:33 PM
1775.Z28
Jan 11, 2015 10:51 AM
BLOWNBIRD
May 28, 2003 01:02 AM
