2002 35th Anniversary Z8 Camaro
Old May 15, 2005 | 10:35 AM
badapple's Avatar
FOR SALE
2002 35th Anniversary Edition Chevrolet Z28 Camaro
(Last year of production)
One owner, In Service Date: 03/15/2002
Excellent condition, 9,500 miles
Sunset Orange Metallic, w/black roof panel
5.7 Liter all aluminum LS1 V8, 310 rwhp @ 5,600 rpm(without modifications).
Stored 6 months each year(Oct.-Apr.).
FACTORY INSTALLED OPTIONS
16” Chromed aluminum 10 spoke wheels.
Good Year P245/50 ZR-16 radial b/w tires.
Ebony leather interior.
Leather wrapped steering wheel w/radio controls
Rear window defogger
PERFORMANCE MODIFICATIONS
• Nitrous Express #20920 50-150 adjustable h.p. system w/purge valve, fuel pressure safety switch, N2O pressure gauge, bottle heater, N2O filter, &
fuel line pressure gauge.
• MSD rpm activated window switch, w/rpm modules.
• SLP lid w/K&N filter kit.
• SLP smooth bellows.
• SLP 160* thermostat.
• SLP line-lock.
• SLP large diameter s/steel y-pipe.
• SLP loud mouth cat-back exhaust,(s/steel with slash-cut tips.).
• SLP strut tower brace.
• SLP sub-frame connectors.
• SLP driveshaft loop.
• SLP skip-shift eliminator.
• SLP leather shift handle.
• Speed Inc. throttle body by-pass.
• Spec stage 3 ceramic clutch kit.
• Spec steel billet flywheel.
• B&M super ripper shifter.
• Performance Suspension urethane transmission mount.
• BMR adjustable torque arm w/urethane torque arm bushing.
• BMR adjustable pan hard rod.
• Thunder Racing lower control arms.
• Moser 12 bolt rear w/4:30 pro street gears, Eaton 33 spline posi,
billet end caps, 33 spline axles, long length studs, large U-joint.
• Moser billet aluminum cover w/adjustable cap studs.
• Harlan programmable shift light(mounted in pillar post).
• Diablo Sport Predator pcm tuner/scanner w/ custom tune for N2O included.
• NEC Pentium 2/433mhz laptop computer(for Predator tuning).
• Rear floor mounted fire extinguisher.
• Ram air modification to air box completed.
• Drill modification to slave cylinder completed.
• Throttle body by-pass modification completed.
• Mickey Thompson ET Street tires 10.5 x16, mounted & balanced, on 9” Chevrolet 10 spoke aluminum Camaro rims.(These are off car, and included with purchase).
• Ported/posished/descreened factory MAF sensor(included).
• Factory cat-back exhaust approx. 1,000 miles(included).
• Factory clutch w/flywheel w/approx. 9.000 miles(included).
• Technical and installation manuals, receipts etc.(included).
• $18,000.00
• (413)594-4888(home)
• (413)977-3096(cell)
potvinpe@netzero.net
rockync7
Jan 1, 2015 05:10 AM
ANDYZ28
Dec 29, 2014 09:13 PM
ChrisFrez
Aug 12, 2002 11:50 AM
Red97LT1
Aug 4, 2002 08:01 PM
