New NHRA rules and MRP?
Old May 3, 2005 | 01:06 PM
Camaro ChriSS's Avatar
Has anyone been to Mission yet and 'tested' or inquired about the new NHRA rules?
In particular, running 11.50-11.99 and not requiring a rollcage. I'm just curious if they are applying that now, and HOW they are applying it - that is, how will a modded f-body running high 11's be received. Instant kick-off? I think the rule technicially only applies to stock cars in that ET range, such as Vipers and such, but it depends how strict they want to be.
Old May 3, 2005 | 02:07 PM
JD30thZ28's Avatar
Re: New NHRA rules and MRP?
I will let you know in a few weeks
Old May 3, 2005 | 02:26 PM
Oh? Interesting...
Lol! I may have to beat you TO the track.
Old May 3, 2005 | 02:40 PM
John1975's Avatar
If your car is on "the list"..............you can. At least I was told I can run that without cage. But if I keep getting beat by damn ******* wagons (GERRY), I won't be in the 11s anyway.
Old May 3, 2005 | 02:41 PM
JD30thZ28's Avatar
May.20th test and tune, let's all go
Old May 3, 2005 | 05:38 PM
20th might be a good idea.
Old May 3, 2005 | 06:15 PM
Erik's Avatar
Classic Tech Moderator
This is from MRP's website:
Basic Tech Rules & Regulations:
* All cars must have seat belts.
* All cars require a 16oz or larger radiator overflow can.
* All vehicles must drain antifreeze prior to racing (except 1995 or newer stock cars and trucks with sealed factory coolant system). Bring a plastic container.
* No plastic or glass fuel filters allowed.
* No plastic oil pressure lines allowed.
* All vehicles must have a functional neutral safety switch.
* All batteries must be securely mounted (no bungee cords, rope, wire etc) Relocated batteries please see NHRA Rulebook.
* The trunk and passenger compartment of the vehicle must be empty prior
to racing.
* Drivers must wear pants and long sleeve shirts ( no shorts or T-Shirts allowed).
* Drivers of cars running 13.99 or quicker are required to wear a NHRA Approved Snell 95 or newer helmet.
* Cars running 12.99 or quicker will require a driveshaft loop.
* Cars running 11.99 or quicker must have an approved roll bar, SFI belts & jacket.
* Cars running 10.99 or quicker must have approved aftermarket axles and harmonic balancer.
* Cars running 9.99 or quicker must have approved roll cage.
One thing not listed is that ALL motorcycles need a lanyard to kill the ignition of a bike if the rider becomes disconnected from the bike. (NHRA says 120mph+ requires lanyard)
Old May 3, 2005 | 06:59 PM
Muskys SS's Avatar
Those are the old rules
Old May 3, 2005 | 09:05 PM
John1975's Avatar
yep
certain cars can run 11.5 without a cage and who knows what else
Old May 3, 2005 | 10:45 PM
Tw!tchb!tch's Avatar
Im in for Test and Tune , Ryan will probably bring the TA too. When can we call up and reserve a spot ??
Old May 3, 2005 | 11:12 PM
Drumhawk's Avatar
High 11's kick *** Chris, go get em.
Old May 4, 2005 | 10:44 AM
As Erik pointed out, that's the rules on MRP's site, and although I know they go by NHRA, some of those old timers there do NOT react to change very well. I notice that MRP has updated their web site, but I found it strange that they didn'y update their track rules at the same time, to be current. Which makes me wonder how they'll respond to the new rules, and interpret them. Of course, probably a seperate person does the web site from the person doing the info updates...
But, I am NOT going to call and find out. That will probably just open up a can of worms. Let sleeping dogs lie for now. I'll wait to see what happens.
Old May 4, 2005 | 10:52 AM
Erik's Avatar
It's very likely that you could get away with a car that meets the new rules, even if MRP would prefer that you meet their rules. You'll probably get away with it a few times, but they won't let you get away with it all year.
Old May 4, 2005 | 12:19 PM
Draco's Avatar
You cannot run engine mods or power adders and still qualify for the 11.50 rule. You are only allowed intake/exhaust/bolt-on changes. Dont discuss your heads and cam if they ask
Old May 4, 2005 | 02:55 PM
Muskys SS's Avatar
That doesn't make any sense... What difference does it make what is done to the car? When the 11.99 was in effect it didn't matter.
