instrument swap ???
Old Apr 30, 2005 | 10:24 PM
raz0r6's Avatar
instrument swap ???
the instument panel swap will the wiring on my 95 v-6 connect to the instrument panel of an 95 lt1 ??? or what is all in volved on this swap.
Old Apr 30, 2005 | 10:39 PM
deadmeat2004's Avatar
Re: instrument swap ???
swaps fine... everything will be ok but the tach will read wrong, but speedo is fine.
Old Oct 27, 2009 | 02:42 PM
raz0r6's Avatar
bump bump anyother inside advice
Old Oct 28, 2009 | 06:23 AM
SupplySgt.'s Avatar
There's really nothing to it. Just take the old cluster out and hook the new one up. as stated the tach will be off by maybe a couple hundred RPM but other than that it's fine. If you take off the back of the cluster there's a couple screws holding down the odometer and it's easy to swap. Nothing to it. I did it on my 96 that I used to have.
David Dempsey
Mar 12, 2016 12:42 AM
blac94Z
Nov 4, 2015 01:59 PM
gonzo275rltw
3rd Gen / L98 Engine Tech
Sep 7, 2015 04:46 PM
gonzo275rltw
Sep 5, 2015 06:26 PM
gonzo275rltw
Sep 5, 2015 06:24 PM
