Rear End ???
Old Apr 20, 2005 | 01:37 PM
RamAirTA95's Avatar
Rear End ???
On a 2002 WS-6, if you jack the rear end up so that both wheels are off of the ground and spin one of the wheels by hand what should the other wheel do?
Old Apr 20, 2005 | 01:53 PM
Re: Rear End ???
Please post questions on this topic in the "Drivetrain" forum, not here on "General Tech".
Old Apr 21, 2005 | 12:36 AM
sir dyno's Avatar
Re: Rear End ???
Im assuming you have posi-traction then the other wheel should spin too.
Old Apr 21, 2005 | 08:33 AM
93LT1355's Avatar
Re: Rear End ???
Even if he didn't have posi the other wheel would still spin its just which direction. IF you have posi and other wheel should spin in the same direction you are turning your wheel. If you didn't have posi the other wheel would turn in the oposite direction.
Old Apr 21, 2005 | 08:44 AM
RamAirTA95's Avatar
Re: Rear End ???
What does it mean if the other wheel does not move at all, but if I start the car and put it in gear they both turn?
Old Apr 21, 2005 | 09:16 AM
cndctrdj's Avatar
Re: Rear End ???
how many miles on the car? and is it the original stuff in there?
Old Apr 21, 2005 | 10:30 AM
Capn Pete's Avatar
Re: Rear End ???
It means the car is in neutral, and you're turning the driveshaft instead of the other axle. Put the car in gear and try again.
NOW, there's a chance that the wheel on the other side could spin the opposite direction even if you have an LSD (limited slip differential) but it only happens with the Zexel Torsen diffs I believe. I know that's what my factory 2.73 diff is, and I'm pretty sure the axles will turn in opposite directions if you just spin one side. The Auburn diff is more like a traditional "posi", and they will always turn in the same direction.
Your '02 T/A definitely came with an LSD, it's just a question of which type, Torsen or Auburn.
Old Apr 21, 2005 | 10:52 AM
RamAirTA95's Avatar
Re: Rear End ???
Thanks Captn that is what I thought, just couldn't remember.
Old Apr 21, 2005 | 10:53 AM
cndctrdj's Avatar
Re: Rear End ???
if he had electronic lockers or air lockers then they wouldnt engage until then had the appropriate medium to them
blac94Z
Mar 2, 2015 06:03 PM
Chet1185
Feb 4, 2015 09:51 PM
jcamaro95lt1
Jan 24, 2015 08:21 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
