What clutch should i get?
Old Apr 19, 2005 | 08:38 AM
Roach02's Avatar
Question What clutch should i get?
I need to replace my stock clutch. the car is a 95' Z28 with 62,000 miles. Also how hard is it to get the tranny out? Someone told me you have to losen the motor mounts so you can jack the engine up in order to get it out. Is this true???? Rather do it myself than pay an arm and a leg for labor cost. What clutch do you guys recommend. I got the 17x11's on the back which isn't helping the stock clutch when i launch.
Old Apr 19, 2005 | 08:46 AM
1-bad-z28's Avatar
Re: What clutch should i get?
The answer is going to vary. I have a centerforce dual friction and love it. You don't have to unbolt the motor mounts to get the tranny out. It is not really a hard job just a pain in the ***. Everything is straight forward and common sense. The only tricky part (at least it was for me the first time i did it) is the clutch fork. Contrary to what the chilton and haynes says, all you do is pull it toward the opening and it is disconnected. Maybe i read something wrong but i had the worst time with that thing. That was 5 years and 5 tranny pulls ago.
Old Apr 19, 2005 | 08:56 AM
69z-28's Avatar
i got 117k on my car and as far as i know its the stock clutch and grabs great, but im not for sure if its ever been replaced. here is a guide for everything u need to do. hope this helps.
http://www.zmydust.com/lt1clutch.html
Ericksd
Jan 20, 2016 06:07 PM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
Bxlt1
Sep 29, 2015 03:18 PM
Ericksd
Sep 16, 2015 07:08 PM
