fast idle?
Old Apr 12, 2005 | 08:33 PM
hates rice 24's Avatar
fast idle?
I tried the search and couldn't find anything. My car has always ran around 700 rpm at idle. i haven't driven the car for a while. When i took it out for a nice sunday drive, it starts and idles fine, but when i actually put it in gear and drive, when i come to a stoplight or something it idles at like 1200 rpm. shut the car off try again, same thing. The only thing i can think of that happened with the car is i might have hit the rev limiter but most likely not while driving earlier that day. I have checked my airlid and filter, no loose hoses or anything like that....please help with any ideas. I have also disconnected the battery. My cats sound like they might possibly be going bad, could this cause any problems related to this? Thanks for any help you can give me. Let me know if you need any more info.
Old Apr 13, 2005 | 08:28 PM
Re: fast idle?
anyone?
Old Apr 14, 2005 | 08:12 PM
BirchMan98z's Avatar
Re: fast idle?
If you haven't driven the car in a few weeks/months it'll do that for a few days. Fuel/timing was probably a bit mixed up.
Old Apr 14, 2005 | 09:48 PM
adimo's Avatar
Re: fast idle?
he man i had put my car away for the winter and when i went to get it like a month ago i had the same problem. when i started it it idled high when i gave it some gas it went up to like 2500 rpm and stayed there. and i was like what the hell the funny thing was it was in my grampas driveway and it was offly loud i didnt know what to do so i turned it off and started it back up same problem. i check everythihg like u did and nothing then i went over to the computer and unpluged the 3 plugs on the left side "if you where facing the car" of the car. the car then shut off on its own i plug back in and then started it back up and no problems checkingen was on for a lil then went away that weekend i had went to emmitions and passed so i was all good. i also know a kid who has a 02 and had same problems and he just ran it for like 45 min and the problem went away. i think that the computer has to relearn all its habits. well i hop this was a lil helpfull.
Old Apr 15, 2005 | 05:27 PM
Bayer-Z28's Avatar
Re: fast idle?
Might have been doing that to get the voltage back up in the batt..The alt adds a load and the comp compensates for it by upping the idle a little. VIA, IAC motor...
Like what was said above, mixtures might have been a little screwed up too..
Mine does that when I haven't driven her in a while..
Old Apr 16, 2005 | 12:04 PM
Re: fast idle?
Thanks guys, i hope thats it...I haven't driven her since so i will have to take her for a spin to see if that helps...i was taking a little joyride before i was going to order some longtubes, and then that happened. I would be happy if that is all it is so i can order away. thanks again
Fastbird93
May 22, 2015 08:28 PM
maybe2fast
Apr 23, 2015 08:55 AM
maybe2fast
Mar 16, 2015 09:45 AM
ChrisFrez
Mar 1, 2015 01:33 PM
maybe2fast
Feb 5, 2015 05:14 AM
